Cats off?
Old Jul 2, 2003 | 10:09 AM
coops's Avatar
coops
Cats off?
I've made up my mind to remove my cats. oh yeah, 1994 I6 2wd. I'm a novice so I thought it would be no big deal but...There are, as you all know, 2 pipes comming off the manifold into the first cat. Well now, how do I connect the 2 pipes into one?
Old Jul 2, 2003 | 10:28 AM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Cats off?
Why bother removing the cats?? If you are after performance, buy a catback exhaust system.
Old Jul 4, 2003 | 12:10 AM
Budly's Avatar
Budly
Cats off?
dont connect them into one, just run duals out the back of each side, it sounds better than on pipe, as far as taking cats off goes, you should increase power a little and gas mileage a little. and its ALOT cheaper than a catback system (if you do it yourself)
Old Jul 4, 2003 | 12:27 AM
Torque1st's Avatar
Torque1st
Posting Legend
Cats off?
Run a single pipe. If you knock the innards out of the cat it will join them together real well then run a single pipe to the rear with some good mufflers.
Old Jul 4, 2003 | 07:59 AM
paulfix's Avatar
paulfix
Cats off?
Keep your pipe diameter at 2.5in for a single pipe and 2in for duals to best match the 300, otherwise you will lose lots of low and mid range power and torque
