syn. trans. fluid ?
Old Jul 2, 2003 | 07:37 AM
treb's Avatar
treb
syn. trans. fluid ?
is syn. trans. fluid better to use than mercon atf. in 5/speed man. trans? 99ran. mazda trans. lot a stop/go/ long trips. is there something better than 80/90 use in diff.? thanks
Old Jul 2, 2003 | 10:19 AM
Rancha9's Avatar
Rancha9
syn. trans. fluid ?
Use what the manual calls for. These little 5 speeds are pretty rugged, and I wouldn't worry about burning it up anytime soon. As for your rear diff., it doesn't use 90 weight, it uses a special ford-concocted-never-has-to-be-changed-unless-you-get-water-in-it lubricant that works quite well.
General Rule:If it's not broke, don't go fixing it.
Old Jul 2, 2003 | 12:49 PM
treb's Avatar
treb
syn. trans. fluid ?
your right if aint broke let it be good info rancha9 i will stick to the owners man. guess looking for better aint always better
