cab corner time...
Old Jul 2, 2003 | 12:10 AM
77dream's Avatar
77dream
From: In a town where there is never anything to do
cab corner time...
Hey everybody...Good to be part of this forum...
Just got a 77 F150 Custom...Flat bed, 351M etc...
Noticed that its hard to get it in 1st gear..Went right to the cab corners..D/s ok P/s DEAD!!!!
Any sugestions on how to replace the P/S cab corner..Any comments wecome.
Thanks, Mike
Old Jul 2, 2003 | 12:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
cab corner time...
Do you have a floor shift 4 speed? If so the transmission probably has an unsynchronized "granny" first gear that is normally not used for driving. Granny gear is for running slow over rough terrain or for pulling stumps. You start the truck out from a stop in second gear.
Old Jul 2, 2003 | 12:40 AM
79_custom's Avatar
79_custom
cab corner time...
First things first...you need to find a company that sells them, I think cab corners sell for like 19 bucks...
when you get it in, hold it beside the old corner to see how much you want to cut out..there easy to cut out, any cut off tool will get it right out..next put the new one in.. are you any good with a mig welder?...if you are line it up and tack it in, dont hold on one tack for too long or you will warp youe metal.. thats no good..hehe
After you get it tacked in.. Go all around it with tacks welds untill you get it all welded up..
Next, grind the tack welds smooth and use a fiberglass filler to smooth things up, sand, primer and paint...
Good Luck!!
_Evan
Old Jul 2, 2003 | 11:07 PM
77dream's Avatar
77dream
cab corner time...
ya it has a 4-speed floor mount
The "start in 2nd gear" makes sense to me..I'll take ur word that 1st gear is useless unless goin muddin or something like that.
Mig welding
Yeah Welding is what i do for a living so i wont struggle there..so whats the trick in jacking the cab up..
Old Jul 2, 2003 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
cab corner time...
That granny gear is unsynchronized so you can't downshift into it unless you double clutch which is pretty hard to do if you are slowing at the same time. In order to sync up you almost have to be stopped. I can do it because I spent many many hours operating a dual tranny setup where there was a 4 or 5 speed synchro tranny with a 4 speed unsynchronized box behind it that you were constantly shifting. Once you got the rhythm of it shifting was easy. I was driving a big redi-mix truck with a gasser 534 cube motor. It worked good out in the flat lands of central Kansas and I got 4 mpg out of those beasts. None of the other drivers got over 2 mpg which drove the boss and the mechanic nuts. The dispatcher would shift me around to other trucks as a vacation replacement and I still got 4 mpg no matter what truck I drove I carried just as many loads too. My reg truck only carried 7 yards state legal and some of the newer trucks would carry 8 yards. We didn't have the extra wheels they have on them now. As you might guess I liked driving them nuts...
Old Jul 5, 2003 | 04:59 PM
79_custom's Avatar
79_custom
cab corner time...
You wont really have to jack the cab up..The way I did mine was to get the bolts out of the bed then pull it back enough to work on it..
Old Jul 5, 2003 | 05:19 PM
77dream's Avatar
77dream
cab corner time...
It has a flat bed so I dont know if that makes any difference..So just un-bolt the cab mount bushing the way it sits? Wont it need some support to get the bushing back in when the new mount is welded in place?
Old Jul 5, 2003 | 05:33 PM
79_custom's Avatar
79_custom
cab corner time...
So whats really rusted out the cab corner on the p/s or the cab mount??....I think I may have mis understood ya..
Old Jul 6, 2003 | 01:28 AM
77dream's Avatar
77dream
cab corner time...
ahh sorry bout that..Their both pretty hurting
Old Jul 7, 2003 | 01:12 AM
79_custom's Avatar
79_custom
cab corner time...
thats alright man.. yea you'll have to jack the cab up to fix that mount.. there is a crossmember that runs across the cab floor.. that would prolly hold the weight of the cab pretty good...mine was still in great shape, where are you from up north??...
Old Jul 7, 2003 | 05:09 AM
77dream's Avatar
77dream
cab corner time...
Im from Quakertown, Pa bout 45 Min away from philly
Old Jul 7, 2003 | 10:51 PM
79_custom's Avatar
79_custom
cab corner time...
oh.. I thinking the road salt may have eaten it away or something...Im like 500 miles south of you...
Old Jul 8, 2003 | 01:40 AM
badass truck's Avatar
badass truck
cab corner time...
yea my 79 f-250 , the cab mount holes, where the bushings go.. are like all rusted. i just found a peice of scrap metal and cut a new hole, then welded it on there
iggybob44
Oct 28, 2013 07:46 PM
4x41977
Nov 15, 2012 08:44 PM
xfordman
35
Mar 18, 2005 05:25 PM
q_ball
Mar 19, 2001 09:54 AM
