ABS Module Location.
It has had the Brake light and ABS light on for a long time. Using Snap on reader, we are unable to get and brake codes. We are suspecting that the ABS module is bad, but we are unable to find it. Where is it located.
Also, an unrelated problem. It seems that the van has plenty of low end power, but feels like it runs out of power as it builds RPMs. If you try to press the accelerator down more, it will never shift. You have to lift almost completely off the the pedal to get it to shift each time.
I've done some reading on this and have heard in may be the exhaust back-pressure valve. We did clean this last fall and it made no change. Right now, the biggest priority is the ABS module though.
Thank You.
