VIN
Old 04-19-2014, 12:35 PM
Kamstutz's Avatar
Kamstutz
Kamstutz is offline
VIN
Is anyone able to tell me what options are on this truck? Should be a E99, 7.3, XLT, 4X4, manual lockouts, extended cab, Grey interior, automatic, Black with a gray bottom.
1FTSW31F9XEC65041
Thanks! Kevin
Old 04-19-2014, 01:18 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Note that the VIN turned itself into a link. Click it to go to the site's VIN decoder.
Old 04-19-2014, 01:44 PM
Kamstutz's Avatar
Kamstutz
Kamstutz is offline
I saw the VIN decoder but I was looking for the options.
Old 04-19-2014, 02:15 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
What options in particular?
Old 04-20-2014, 02:09 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is online now
Okay I want to know how to get the front spring code out of this. I need to find mine for my CC 4x4 lb. Thanks a head of time.
Old 04-20-2014, 09:04 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
I think there's a spring code on the driver's door pillar around the VIN.
Old 04-20-2014, 11:08 PM
Bonanza35's Avatar
Bonanza35
I've been told that but just haven't figured it out yet. It don't say spring so I'm not sure how to find it.
Old 04-20-2014, 11:16 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I think it says front vehicle gross weight or something like that..
Old 04-20-2014, 11:25 PM
Bonanza35's Avatar
Bonanza35
Phil, I think I did see that. I'll look again and see if I can see a code. Thanks,
Old 04-21-2014, 05:56 AM
Walleye Hunter
On the bottom line of my tag is a series of abbreviations. The last one is SPR, I am guessing this is a spring code but am not sure. Mine says VA there. My www research shows that there are only a couple of different springs used on these trucks.
Old 04-21-2014, 06:12 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Fortunately, there's a door sticker decoder too
Ford Door Sticker Decoder | Ford Trucks
Old 04-21-2014, 09:19 PM
Bonanza35's Avatar
Bonanza35
All right guys. Just went out and checked, its funy, I never saw that SPR before. I guess its got to do with my glasses but above the SPR is DSO, and below it is VC? So I'm guessing its code is VC. Being a CrewCab 4x4 with LB I thought it would have X code springs? Any way I'll have to check on price and replace them. Don't really want to go extra heavy so I thought just same springs, what do you all say?
Old 04-22-2014, 04:07 PM
brian42's Avatar
brian42
brian42 is offline
I think the V is the front spring code (for the diesel, 5200lb rating per spring pack) and the C is the rear spring code. I know that the only springs up front that are heavier than the V code for the diesel is the X code for the plow package (popular swap to get the front about 1" higher).
Old 04-23-2014, 12:02 AM
Bonanza35's Avatar
Bonanza35
Thanks Chief. I wouldn't mind the 1 inch higher I just don't want it stiffer then it was new. I would think if they put the V code on the shorter wheel base diesels they would use a different one for crew cabs.
Old 04-23-2014, 06:10 PM
Walleye Hunter
Here's a link to a spring company. If you scroll down to the F-250/F-350 section you can see what is available. There are basically two options for each application-regular duty and heavy duty.
http://www.stengelbros.com/HeavyDutyLeafSprings.htm
Quick Reply: VIN
