Looks like you left the factory rear blocks in. i could be wrong but that's what move logged like before i called and talked to bds. They told me the all spring lift is designed to be installed without blocks. Their isntruction are not that great. Anyways it looks great i have three same lift. After i pulled the rear blocks out it road so much better. The shocks where not made for that much lift.
Looks like you left the factory rear blocks in. i could be wrong but that's what mine looked like before i called and talked to bds. They told me the all spring lift is designed to be installed without blocks. Their isntruction are not that great. Anyways it looks great i have the same lift. After i pulled the rear blocks out it road so much better. The shocks where not made for that much lift. It also has a better stance. Almost level but ever so slighty higher on the rear. I could be wrong let me,know. Logs great
IWas Just talking To My Bro In Law Bout That. I Don't Like It High In Rear Like That. Might Take That Block Out. Did You Have Drive Line Vibe?
Sorry about my earlier post it was with my cell phone. So I had a hard time with auto correct.
I would definetly take the blocks out. Just because the shocks are designed to be a 4". If you go with a 6" lift it calls for a different shock. Plus when I called and talked to BDS they said the 4" rear springs specs are set up for no blocks. So you basically added a 6" rear lift and 4" front. I do not have any driveline vibration. I did install dual front stabilizers with my bds kit. I do not know if that helped. Your drive line vib may go away after your take the blocks out. The Ujoint angle wont be as harsh. I read some posts about shimming the driveshaft angle, If your vib doesnt dissappear maybe worth a it to shim it. The good thing about removing the blocks is it will be a quick 20 minute job. Dont forget to retorque after a few hundred miles.
anything over 5in the rear will have the drive line vibration from my experience. i would think it would at least lessen if not go away if you remove rear blocks.
