Radius arms and steering
Old Jul 1, 2003 | 08:33 PM
Jerrybo66's Avatar
Jerrybo66
My 73, F-100 has steered hard for the last 20+ years..I don't have power steering and always blamed the steering problem on radius arm bushings..They seem tight, no movement... Would they cause it... The truck always drives straight , has been four wheel aligned , steering box lubed, all front end parts good... I resigned myself to exercising my arm muscles years ago but being the radius arm subject was brought up, I thought I'd ask your opinions of what could cause the hard steering... Thank ya' much...
Old Jul 1, 2003 | 08:57 PM
LxMan1's Avatar
LxMan1
Only if you have too much caster. I don't think that they will have much effect on the steering hardness. I would look into seizing kingpins.
Jimmy
Old Jul 2, 2003 | 06:19 AM
laptopgeek's Avatar
laptopgeek
Jerrybo66 ~
My '74 is the same way.....I can take everything OFF the darned spindles and it takes all that I have (and I lifted weights for about 6 years while training for the Mr. Georgia trophy) to turn the spindles left or right!!
Sounds to me like the kingpin bushings are frozen up. I have replacements and will be installing new pins / bushings this weekend..I'll let you know how it turns out....maybe even with an MPEG on my web site demonstrating the before and after...
Old Jul 2, 2003 | 12:47 PM
Native Gearhead's Avatar
Native Gearhead
I had my '74 apart this weekend doing brakes (everything off), and the spindles moved easy with just one-hand torque behind a 9/16 wrench. There isn't much else down there that could be causing that other than kingpins. I could tell mine were replaced by the new grease fittings and other newer front end components.
The radius arm bushings will give you slop in the steering, clunks, and mis-alignment (front to rear as opposed to top to bottom), but I don't think they would make your steering hard.
