transmission loading
Old Mar 10, 2014 | 10:02 AM
caddypat's Avatar
caddypat
hi all.i have a noobie question im sure has been addressed before. my rig is a 2001 f350 2wh drive. 7.3 eng. i bought the truck at 134000 mi.not long after the purchase i started feeling the tranny was not quite right. now at 142000 mi the tranny took a dump. i had a ford reconditioned unit installed @ a total price of 3500.00 including a new external cooler per ford instructions. i haul an 11ft. camper weighing about 4500 lbs. never having owned an automatic before i want to use it properly.while hauling the camper can i just put it in drive and forget it or do i not use the overdrive at all or kick it out of overdrive when approaching a steep grade. my owners manual do not address this at all.any advice will be appreciated . thanks pat. ps i hope this is in the proper area and formst.
Old Mar 10, 2014 | 11:02 AM
Robert6401's Avatar
Robert6401
At 4500 lbs, I can't imagine you would ever really need to take it out of OD. But what is generally recommended is to run it like normal unless the transmission is hunting for a gear between 3rd and OD while climbing hills. Then you should turn the OD off and just run in 3rd until you're back on level ground. Again, I don't think this is going to be a big issue with the weight you're towing unless we're talking about some really steep hills.
Old Mar 11, 2014 | 02:56 PM
caddypat's Avatar
caddypat
hi robert6401. thx for the reply. thats kind of what i thought but to get some other opinions. thx again pat.
Old Mar 11, 2014 | 04:11 PM
HKusp's Avatar
HKusp
Typically, 4500lbs should not require taking it out of OD. The big thing is getting an exhaust gas temp gauge and a tranny temp gauge to be sure. If you are running extended at a decent grade with a stock exhaust, you could potentially build up exhaust temps that could cause issues. I would at LEAST put a real tranny temp gauge on it.
Old Mar 12, 2014 | 12:17 PM
thomabb's Avatar
thomabb
I've pulled a 16ft dovetail flatbed with a small car (Grand Am, etc.) on it multiple times. I never ran across the scales, but my guess would be somewhere around 5-6k in weight. Truck ran like there was nothing back there. OD stayed on. No problems.
With the 9k 5th wheel, I only turn OD off on long or steep grades. Flat running at highway speed in OD is no problem.
Old Mar 12, 2014 | 12:39 PM
caddypat's Avatar
caddypat
hi all, thanks for all the info. sounds like im good to go. just did not want to mess up a 3500.00 repair due to ignorance of the product. pat
Old Mar 12, 2014 | 12:46 PM
thomabb's Avatar
thomabb
You'll want to be easy on that rebuild for a little while. She will need a break-in period.
Patton531
May 17, 2013 03:14 PM
Cannonball02
Sep 11, 2007 09:29 AM
parkland
17
May 6, 2006 09:04 PM
raydar
Jul 22, 2005 12:35 AM
jamess67
All Things Towing
Jun 9, 2003 03:56 PM
