So I searched the threads and tried to identify the code off the rear diff tag, I cant seem to figure it out. So, can you guys help me with this tag, the wheel cylinder or axle seal is leaking and a brake shoe spring broke, so needless to say I need to rebuild the rear brakes on this rig now...
Rear Diff Tag Reads: V131C 4L10 10 2 9F08
Also, I cant find a nice photo showing the rear brake setup on this. The emergency brake cable, coil spring section, is rubbing against the hub/ part that has the wheel studs attached to it. I dont know if this is due to the spring snapping, or if it snapped due to rubbing on the hub assembly. Does anyone have a photo showing how it correctly assembles?
