Wheel bearings?
Old Mar 9, 2014 | 11:09 AM
duggyb's Avatar
duggyb
Wheel bearings?
Well i think my front wheel bearings have been getting bad. and i took my truck(94.5 f350 7.3 4x4) on a 6 hour round trip yesterday and i think its getting louder so i need to do them ASAP.
if I am on the highway whenever i turn right or am going slightly right there is no noise, if I am going straight there is a very faint noise and if i do a left turn at anything over 80km/h then i really hear a growling/whining noise and can feel it in my left foot kind of. the faster i go the louder it is.
would this be wheel bearings? i just replaced all of my tie rods with Moog stuff and got an alignment so i know they are good.
is this what i need from rockauto?
1995 FORD F-350 7.3L V8 DIESEL Turbocharged
Brake/Wheel Hub : Wheel Bearing
SKF Part # BR38 {#15042154, 9428908, 9739NO38SET, C7TZ1239A, C7TZ1240A, YC3Z1109AB} Tapered Bearing Cup & Cone Set
Front Outer; 4WD; Spicer 50 & 60 Axles
CAD$15.32x2 CAD$30.64
SKF Part # 387A {#03582, 0634049, 0634050, 1114151, 11621607, 11634049, 1799296, 18500, 455500, 455501, 457168, 5269648, 527521, 530647, 634049, 640080, 71LB4220A1A, 7451692, 7451693, 8124028, 918400, 9412406, 9412407, 9412408, 9412411, 9422481, 943660, 9441046, 9980739, B5D4221A, B5Y4242A, GBT307781, GTB307781, J0918400, J0943660, J8124028, TB6326, TBAF4221A, TCAA1244, TCAA1244A, TD50444, Y387A} Tapered Bearing Cone
Front Inner; 4WD; Spicer 50 & 60 Axles
CAD$17.06x2 CAD$34.12
SKF Part # 382A {#0009813580, 0009813580KZ, 0009814581, 0009814581KZ, 142223, 15042155, 3838017, 568500, 583, 664736, 7451691, 8983501507, 919661, 943660, C5NNA768A, C5NNP777A, J0919661, TCAA1243A, Y382A} Tapered Bearing Cup
CAD$9.91x2 CAD$19.82
Brake/Wheel Hub : Wheel Seal
SKF Part # 27452 {#1090672, 15526365, 15582232, 2100863, 2365606, 3821519, 463478, 463748, B2TZ1175A, C1TT4676A, D8TZ1175B, NCB4380A, TCAA1175A} Grease Seal (Only 2 Remaining)
Front; 4WD; Spicer 50 & 60 Axles
+ Sold in packs of 2; Price reflects cost of each individual item, not the pack
CAD$11.15 CAD$22.30
Subtotal CAD$106.88
Country: Canada, Zip/Postal Code: T2G 4A1
Shipping: Ground (5 to 6 business days) from United States CAD$44.65
Total CAD$151.53
Old Mar 10, 2014 | 05:11 AM
84-250's Avatar
84-250
What about new bearing races?
You have the tool for the spindle nut?
Old Mar 10, 2014 | 09:13 AM
duggyb's Avatar
duggyb
If you look there you will see the one bearing comes as a Cone & Cup pair. So a complete bearing I assume it means. And I got 2 of those.
Then the other ones are separate bearing and races aka Cone & Cup which I also ordered 2 of each.
And yes I bought the special tool the other day, I am pretty sure its the right one. If not I know the parts store also had the other one so I can go swap it.
Just looking for Confirmation these are the correct parts I need?
chirkware
Jun 16, 2019 10:21 AM
PaulTMurphy
Jun 2, 2017 05:18 PM
PinkyRingz
Jan 4, 2016 08:19 PM
48' fordster
May 5, 2010 12:49 PM
whatapiece
Oct 26, 2009 04:14 PM
