stroker cranks
Old Jul 1, 2003 | 06:35 PM
There Goes The Neighborhood's Avatar
stroker cranks
I'm looking for a manufacturer of forged steel crankshafts. I want the motor to stand up to 10000-11000 rpm blasts when i get stupid. i cant find a manufacturer that makes the cranks and they should. maybe im lookin in the wrong place.thanks in advance.
Old Jul 1, 2003 | 07:52 PM
77460ford's Avatar
77460ford
stroker cranks
SCAT makes both cast and forged cranks for various displacement strokers. If you type in scat and 460 in google you'll find several places that offer different combinations depending on the size of your wallet. Good luck.
John.
Old Jul 2, 2003 | 03:04 PM
proeliator's Avatar
proeliator
stroker cranks
Dood, you are smoking crack if you think you'll be able to spin eleven large. The pro-stockers don't even see that! Even if you spend 3g on the crank what are you planning on putting in your lower end, unobtanium? Anyways, Scat seems like a good place to start I just wanted to fling out a little big block reality check so the Scat techs don't think your a loony. No flame intended.
