I'm in the final stages of my 66 custom cab restoration, and am installing the new front windshield. I have the correct weatherstripping (with slot) to accept the stainless steel molding. Unfortunately I botched the steel molding during the initial pull, so have had to search salvage yards for a another set. Fortunately, I've located a 64 which has the original windshield and associated molding. At first glance, they appear to be the same. My question to you:
Will my truck (the '66) accept the stainless window molding from the '64?
Really appreciate your thoughts Roger. I'll get pics posted of the final condition in a few months. My truck is w. white and arcadian blue for what it's worth.
John: I'm relying on a friend who's done this before, as well as friendly comments such as yours. Greatly appreciate your confirmation and words of advice!
Best, Idaho
I based my comment on your use of "I botched". Usually that means someone was trying to pull the metal while still installed.
Don't know your buds methods, but a good way is to use a 3/16" cord pulled into the cab slot center bottom around to center to pull the inside lip in.
The gasket is meant to install without sealant. I do believe that most here do now agree that sealing is preferred because of leaking.
Thanks for the schematic and advice.....really helpful. John you're correct that I botched it when I pulled the trim and didn't know the windshield needed to be pulled as well. Thankfully I found the 64 with original windshield and perfect trim at a local salvage yard. I won't make the same mistake twice.
LOL! I guess that means you have a leaker..... So do I! I have new carpet but I don't want to install it till I replace the windshield gasket.
Seems that there was a discussion about 6 months back and most now say seal it. You should be able to seal it in place, I would think. Life seems to be moving me further away from my old truck.
