Question for Suspension Guru's:
Old Mar 8, 2014 | 11:40 AM
  #31
Hdslider's Avatar
Hdslider
Bottom line why waste money on a truck that will never ride real soft. Simply trade for a lighter duty truck. World of difference in ride.
Old Mar 8, 2014 | 11:43 AM
  #32
Evilsports's Avatar
Evilsports
Originally Posted by Tom
But what if you DON'T put a few thousand pounds in the back and fly down a back road? In that case wouldn't you prefer a Cadillac?
This is my situation. I won't ever use this truck to it's capacities, having gotten out of our rv. I'm ok with this with the caveat that I need to improve the non towing/lightly loaded ride, which will constitute 100% of my future use.
I'll swallow the size and mileage of this truck in exchange for the room, comfort, and storage as long as I can get this suspension dialed in.
Old Mar 8, 2014 | 11:53 AM
  #33
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by XXLTexan
I agree with RussB's recommendation about driving one before you buy anything. If you can't drive the roads you are getting bounced around on do your best to recreate them. Sounds like work cause it is. My'05 Dodge beat me to death as I mentioned earlier. I changed components one by one and when I was done I found I had not changed the core problem. I was checking out my buddy's lift on the the way home from a gym we used to go to and fell asleep in his truck because it was so smooth. That was 10 years ago when KORE was the new thing for dodges. They addressed the suspension with their kits as a whole. Wheel/tire combos running very low psi. Deaver springs that were sourced and ultimately made to their in house specs. Rear leaf packs that were specific to truck and eliminated overload springs and steering and...you get it. When I had my kit installed on the dodge it was a totally different truck. Then it was stolen (twice second time for good) and I bought an '07 and drove it from the dealership to the shop that installed my second KORE kit. Since I had burned myself doing it my way the first time I researched every kit and when I bought my KORE kits I did everything they recommended even though a lot of what they said was counter intuitive. I had a really hard time with the low air pressure they recommended but deferred to the experts and ended up with a 7500 lb Raptor stomper. Fast forward to the '13 in my sig. I talked with everyone I could find with the search bar and after countless emails and PM's and more than a few phone conversations with Dan at Carli found some common themes. One is that the wheel/tire/tire pressure combo is the weak link that people are not giving enough weight. I flat out asked Dan "hey if I get the commuter or the pin top (King Resi) 2.5 inch leveling kits and keep my oem wheels and then buy tires when it's time can I get the same kind of performance I had in the KORE (out of biz) on my dodges?" "No way" was his answer. He went on to say that the guys that want to keep a 20" wheel or heaven forbid 22" or 24" are told and should understand the ride off road will be bad. He said they have learned the only way to keep a good ride off road with a 20 is with aftermarket slightly wider 20's and a 37" tire that they only rec. on their 4.5 inch kits. I went to a local shop that does a lot of carli kits for dodges and drove a Ford like mine with a 4.5 inch kit with 2.5 Kings and 18x9's with 37x13.50 Toyo MTs and it drove better than my stock truck on road and the limited time I had off road behind the shop was exactly what I thought it would be...smoooooth. So I ordered a commuter 2.5 inch with fox shocks, 18x9 aftermarket wheels and a steering stabilizer. As soon as my tires (35x12.50 Toyos) come in ill post pics on here and a vid on my YouTube channel with the same name and y'all can decide for yourselves if a real suspension system makes a real diff. I asked Dan for permission to paraphrase our conversations to put info on here for the "use the search bar" guys on here so there it is. Last thing, I did not go full kings yet as I had to buy wheels and tires but may upgrade in the future and chose a 18x9 inch wheels as 37's are a little big for my lifestyle: Kids, car washes, and parking garages.
You are very right - on 17-18" wheels with a tall profile (75 section or greater), probably somewhere about a 1/3rd of your suspension travel in high speed bumps will come through tire deflection at normal operating pressures. You can easily increase this (and effectively soften up your suspension) by dropping tire pressures. Obviously the TPMS may have to be recalibrated/ignored, you may get slightly worse milage on the hwy, and if you are carrying a heavy load you will need to bump the rear pressures back up.
I personally think Rim's need to be no larger than to clear the brake callipers (even if you do lose some stability). I like the look of the 20's on my truck (they came with it), but when it comes to replace tires, I'm thinking hard about a 17" steel wheel/tire combo.
Old Mar 8, 2014 | 12:00 PM
  #34
jimmystoys's Avatar
jimmystoys
I agree with BigF350 on the tire/rim combo, and/or going to a half ton.
Old Mar 8, 2014 | 12:15 PM
  #35
Randy_270's Avatar
Randy_270
Originally Posted by RussB
A guy I work with has the full blown Carli kit with King shocks... Just have to tell you, I'm not all that impressed with it and neither is he. He said he'll never buy another one. Before I sank a ton of money into it..... I'd strongly suggest driving in one that has it ! JMO
I understand not everyone will enjoy the ride on road but I'm not buying it for its on road performance, I'm going Carli for their off road performance because I drive a lot of bad gravel roads. The suspension on my truck rides like crap already so it can't get any worse, and I already planned on lifting my truck so why not get a kit that's going to ride better than any skyjacker, bds, pro comp ect.? Also I'm not planning on running anything bigger than an 18" rim, most likely I'm going to wait till my current tires wear out and then replace them with some 35x12.5r17s or 37s on 17s. So I'm sure the ride may not be as impressive as most people think but off road it's going to be better than almost any other out of the box system.
Old Mar 9, 2014 | 03:09 AM
  #36
Bdox's Avatar
Bdox
Aha! Finally a voice of reason!
I have always said just that, the only reason for larger diameter wheels is to clear larger brakes. ( Which I strongly suggest. ) Other than that you are just driving up the price of your tires which are already stratospheric. Other than that you have just fallen into the "style trap."
Old Mar 9, 2014 | 12:24 PM
  #37
XXLTexan's Avatar
XXLTexan
Quote from BigF350:
Quote from Randy_270:
Quote from Bdox:
I agree again. I would run a 17" wheel but most aftermarket wheels won't fit around the newer 2013 caliper. There are a couple that will but have a backspacing or offset that I don't want. That is why I went with an 18" wheel. I have read on these forums that a load range D tire is advantageous for ride quality. I disagree as with most tires when it is time to pull a heavy load/boat/5er you can't safely air the tires up enough. Even if you do and then get into an accident it could potentially be a problem.
I have accidentally said the "R" word (Raptor) on a Ford forum that I am obviously new to and just want to say I think they are awesome. The reason I bring up the Raptor is because it is THE BEST half ton out there for off of the street performance. I have 2 friends that have them. They are great trucks especially how my buddies have theirs set up with aftermarket suspensions ($$) and one even has a roots style blower($$$$). They are completely capable off road and very nice on the highway. Here's the but. Buuuut...my buddy with the big boy Raptor (blower and wild suspension) also has a '06 F-150 2WD extended cab with a 5.4 (blown) and a Camburg suspension kit (not a true pre-runner in case that was what y'all we're thinking) that used to be the Camburg Inc.'s shop truck. That thing, while not as fast as his blown Raptor, can take the big stuff way better that his Raptor with 4-5k in aftermarket suspension. Also my aforementioned '07 Dodge with the KORE kit, Smarty, and a Gorend tranny, ran circles around both Raptors off road, hung with the F-150, and was almost 2000lbs heavier. I say that because I keep reading comments from real truck guys on good forums that these 8500lb Superdutys cannot be expected to ride like a half ton. They can, and depending on the build, do perform better in some cases but you have to be willing to take some info we all know/knew about trucks and chunk it out of the window. I know the Commuter kit I ordered from Carli is different from what I just mentioned. But all I have to do is buy King's (direct replacement) and full progressive leaf packs to replace everything out back and I'm back to the kind of performance I was getting from my Dodges minus the speed (not from the motor but the 10k i had in my Cummins not counting tranny) which is better that any stock "R" word. Last thing...I'm no Dodge or Ford fanboy. I just like what works, which is why I don't like chevy:-(0)
Old Mar 9, 2014 | 12:34 PM
  #38
TRENT310's Avatar
TRENT310
Yeah but for example my D-range tires are rated single 3750lbs at 50PSI... it doesn't need to be at 80PSI to get that rating. Even at that load rating you would be overloading every other part of the truck before the tires, assuming the weight is evenly balanced across the 4 tires of the vehicle.
I went through this thought process when specifying my tires which are 38 on 18s, there are few or no load range E options at that size, but then I realized ply rating doesn't matter when you can achieve the same load rating at a lower inflation pressure. Furthermore with my usage this truck will never meet its GVWR or GCWR.
Old Mar 9, 2014 | 12:36 PM
  #39
Tom's Avatar
Tom
That's true, but the load range of the tire means very little when it comes to ride quality. People like to talk of stiffer sidewalls, but they forget that the rubber sidewalls aren't holding up the truck. It's the air inside, and higher load range tires permit more air pressure.
Old Mar 10, 2014 | 12:20 AM
  #40
RussB's Avatar
RussB
I was talking about off road performance when I wrote this post.. Carli isn't all that its cracked up to be.. I drive more gravel road than most people I know. I guide all over the province, I run lease roads, I use my truck ! Drive one with a Carli before you buy.. That's all I suggested.
Old Mar 10, 2014 | 08:16 AM
  #41
Evilsports's Avatar
Evilsports
Does anybody know for sure if I can fit a 17" wheel over the calipers?
I'm going to snoop around for a set if I can to replace my 20" KR wheels.
I know when I went up to a 20" on my 2006 the ride quality dropped noticeably.
Thanks,
Kevin.
Old Mar 10, 2014 | 11:48 AM
  #42
BigF350's Avatar
BigF350
FTE Emeritus
17" are the smallest that fit (they come standard on some models) on all 05+ trucks.
Old Mar 10, 2014 | 12:32 PM
  #43
Evilsports's Avatar
Evilsports
Thank you.
Old Mar 10, 2014 | 12:38 PM
  #44
nojoke327's Avatar
nojoke327
Wouldn't less air pressure cause the tire to wear funny. I thought I remembered from shop class in school that if pressure was to high the middle would wear faster and if tok low the outer edges would wear.
Also for a softer ride, why not get a softer front spring and remove a leaf or 2 from the rear pack.
Old Mar 10, 2014 | 08:07 PM
  #45
BigF350's Avatar
BigF350
FTE Emeritus
It can, if you lower it too much and do lots of hwy work, gravel road use you won't.
The best way to check on road use is to run a chalk line across the tire tread, drive a hundred feet or so, and see if it wears across the entire line.
In my experience, Super Duties have a wide band of "operating pressure" with the stiff sidewalls of E range tires.
