Anyone have a part number for the bushings that the locating pins push into for the turn signal lights? Mine are worn out on one side allowing the signal light to pull out and sit at an angle. I'm getting by for now with electrical tape wrapped around the locating pin, but I have to push the light back in every other day or so. So far I haven't come across anything at the part stores and my go to guy at the dealership is out for a couple days.
Also need to do a set for a friend of mine. He had his lights replaced at a shop and they removed those bushings and did not replace them at all, so his lights move around and I'm worried the plastic will break soon without them being held properly.
I believe these 11MM push in grommets are what you are wanting,
Ford P/N N811169S or W705550-S300
Park & Turn Signal Housing Grommet
White Nylon
7/32" Stud Size
Head Diameter: 13mm
Stem Length: 9mm
Fits Into 11mm Hole
Replaces Ford: F250 - F550 Trucks 1999 - On
Tousley lists them at 1.98 each, but you can get them online like amazon 50 packs for less than ten bucks.
