where is the temp sensor located at??? more....
Old May 27, 2002 | 12:28 PM
95frd's Avatar
95frd
i thought it was the guage just not working, like lost the ground, BUT when you turn off the key the gauge raises to where it normally sits when the gauge is off, so im thinking the sensor came off where ever it may be. engine block?? i cant find one commin off the radiator, but i havent looked too hard.
Old May 27, 2002 | 02:47 PM
cajunbronco's Avatar
cajunbronco
Is it a 351 or 302? Look on the intake.IT should be screwed into the water jacket.On the 302 the big one in the front is the coolant temp sensor,the small one off to the side is the temp sender.
Billy
Old May 27, 2002 | 04:53 PM
95frd's Avatar
95frd
its a 351. thanks ill try and check it out. hopefully the prob is there.
Old May 27, 2002 | 05:21 PM
mantta's Avatar
mantta
