Engine Check - PNN?
Old Jul 1, 2003 | 12:56 PM
F250_HD_Crew's Avatar
F250_HD_Crew
Question Engine Check - PNN?
I just got off the phone with the Ford Dealer and was told the reason for the E.C. light was a bad PCN (a computer module "brains" for the engine. They want $516 to relace (parts and labor). Ouch! The error codes are P0155 and P0141. ANy advice out there? Any idea on what might have caused the failure. Truck is 97 F250 HD Crew 4x4 with a 460. Recently had the TTB swapped out for a Dana 60. Also have a spuratic Vacuum sounding noise coming from the engine sometime accompanied with a whining sound.
Thanx
John
Old Jul 1, 2003 | 09:56 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Engine Check - PNN?
John, those codes relate to the HEGO sensors. They indicate a "heater circuit failure". I suppose the PCN might cause this, assuming the wiring to the sensors is intact.
The vacuum/whining noise is probably from the idle air control (IAC), and is unrelated to the other problem.
Old Jul 2, 2003 | 06:52 PM
steve83's Avatar
steve83
Engine Check - PNN?
PCM - Powertrain Control Module, aka EEC - Electronic Engine Control, aka OBD - On-Board Diagnostics.
If the computer is spitting out codes, it DOESN'T need to be replaced and that service advisor should be shot. If they don't want to fix your truck for a fair price, just get the Ford/Helm service CD that they use off eBay for ~$10 delivered to your door and fix it yourself. Since you already know the codes, you can look up the pinpoint tests on the CD and find your fault.
Old Jul 3, 2003 | 09:36 AM
F250_HD_Crew
Engine Check - PNN?
I spoke with another Mechanic at a dealership where I have family working. He basically said the same thing. I pulled my truck out of there and am taking it to this dealership. I will post the outcome.
Thanx for the input.
John
Old Jul 3, 2003 | 11:25 AM
F250_HD_Crew
Engine Check - PNN?
Heye steve83
Can the tester to get the codes be purchased as well?
If so, Where and about how much?
Thanx
John
Old Jul 3, 2003 | 11:27 AM
steve83's Avatar
steve83
Engine Check - PNN?
I think places like JCWhitney sell a cheapo that lacks full function for ~$150. If you want a full-function scantool that can read & write Ford codes, plan on $300-700.
Just get a parts store to do it for you. Most of them do OBD-II codes free now.
Old Jul 4, 2003 | 09:11 AM
dro man's Avatar
dro man
Engine Check - PNN?
If the computer is spitting out codes, it DOESN'T need to be replaced and that service advisor should be shot This happens fairly often when one part of the internal pcm fails, it will spit out a code and still be defective.
F250_HD_Crew
44
Jan 30, 2015 10:11 AM
F250_HD_Crew
May 20, 2012 01:07 AM
F250_HD_Crew
Apr 27, 2007 08:55 AM
F250_HD_Crew
Jul 3, 2003 03:19 PM
F250_HD_Crew
Aftermarket Products
Nov 23, 2002 03:56 PM
