New to forum just bought F6 project
She's getting trailered home and torn down before she thinks of seeing the road again. The only real rough spot on the truck I noticed was lots of rust on the roof. This will be a lengthy process but I couldn't pass up the $100 price tag!
Well, cool looking truck. It looks like you have been introduced to your first questions. Widowmakers. The bane of the larger trucks.
Since it sounds like you are staying more stock. You need to get this book on CD.
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
You will also probably need to get to know Chuck from Chuck's Trucks.
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
All the big truck guys on this forum will be a great help with the harder to find parts. There are a lot of us wannabe big truck guys, so we help were we can.
Good luck and be sure to post lots of pictures for us. Take every picture you possibly can as you work on this truck. It's guaranteed you will not remember how things go back together. (Well at least for me anyway.)
Welcome to the insanity!
The bigger trucks share much of the sheet metal and drive train stuff. As for running gear, rear ends, brakes, well, not so many reproductions made for the bigger beasts. Get to know Chuck of Chuck's Trucks, LLC. He'll help with many hard to find parts. Make a plan that fits your budget. Frankly, you can probably expect as much as $2000 or more for wheels and tires.
That's one dirty monkey!
as some have mentioned Chuck's is a good source, but you will be amazed at how many parts for these trucks are available at your local NAPA store. If you get some young kid at the counter that can't find what your talking about, don't give up. Many of us can help you with the proper part #'s.
If you need help with wheels for your truck you will find a few members here who regularly get their hands on the replacement wheels, Truckdog, JMadsen and myself usually manage to find them. Your best bet might be Truckdog, his son is in Oregon and usually has some of the wheels there.
Not sure I'd want to spend that on a $100 truck. And from the description, if I understand correctly, the truck will be apart for a while and won't be needing wheels and tires right away. I agree that the WMs should be either discarded or otherwise rendered harmless, but replacements can wait. There are still yards in Oregon so used replacement lock ring or tubeless wheels and tires could be gathered up as they go. I absolutely agree that Chuck is the best source for big truck parts. Stu
#28
Get the title settled first.
Then, many of us would propose that you get it running and drive it a bit if possible. That will let it tell you what it really needs.
However, as for me, I always do a thorough brake job before most anything else when I start a project. Because, you have to be able to make it stop before you can make it go.
The fuel tank(s?) may be needing help before you trash a newly-built carb or fuel pump, so check it carefully for rust and sediment.
Do not disassemble anything without multiple pictures. If it's not going right back together, label everything. Note long or short screw locations. Get pictures. Box, bag, and label - and then box, bag, and label the labelled bags and boxes. Get the picture? I have been meticulous and I've still had specific hardware magically disappear.
#29
Depends on how far apart you take it. If it will have body removed and take up residence in boxes you will be (like me) having to do probably the chassis first then the body, wiring, etc. Since you are already accepting a long slog with engine, tranny rebuilds, I'd suggest thinking early about the brakes and brake lines. NOS drums don't exist, so finding good used will be needed. Ford spec's on overturning drums is .020 on the fronts, which isn't hard to exceed. Brake shoes will need to be relined too rather than replaced. Master cylinder and wheel cylinders are from Chuck. Brake line comes from Napa or where ever you like. Buy yourself a good double flairing tool and a bender. Stu
#30
