Minnesota Chapter Join Chapter, Leader: fordpower88
March is more winter! BS thread
Old 03-05-2014, 11:40 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
I didn't know that was even possible Chris.
  #122
Old 03-05-2014, 11:54 AM
dlibson's Avatar
dlibson
dlibson is offline
Do you have a clutch puller Jay?
  #123
Old 03-05-2014, 11:56 AM
dlibson's Avatar
dlibson
dlibson is offline
Only by an admin or moderator...
  #124
Old 03-05-2014, 12:43 PM
DieselCamper01
Yes I do.
Too funny they would even bother. LOL
  #125
Old 03-05-2014, 01:28 PM
dlibson's Avatar
dlibson
dlibson is offline
I will have to borrow that someday then.
It is odd. But some people have little better to do...
  #126
Old 03-05-2014, 01:58 PM
DieselCamper01
Any time Dave.
  #127
Old 03-05-2014, 02:30 PM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
Not sure if the Yamaha clutch bolts are similar to some of the skidoos but if so you could use the water method. I've done this to take the clutches off mine. Pull clutch bolt out, lay sled on side, put some water into hole, wrap the bolt threads with that Teflon pipe thread tape, more at top as you wrap it towards end of bolt (stopping at the end of the threads of course), thread bolt in and tighten. Doesn't take much force and it pops it off. Hydraulic pressure.
  #128
Old 03-05-2014, 03:33 PM
DieselCamper01
That is another way Jim but why not just use the right tool for the job?
  #129
Old 03-05-2014, 03:44 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Because I don't want to spend $50-70 on one that I may use every 2-3 years maybe and more apt to break or screw up the threads. Takes very little force using the water method. Cheap and it is easy
  #130
Old 03-05-2014, 03:50 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
If you had purchased a quality American Made sled such as Arctic Cat you wouldn't have to work on it that often...
Sent from my Telegraph using IB AutoGroup
  #131
Old 03-05-2014, 04:00 PM
DieselCamper01
I bought mine back in the 80's when I bought my Phazer. It worked on that, the Vmax, the SRX, Daves SX. Money well spent.
  #132
Old 03-05-2014, 04:04 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Your probably right. The 05, the first time I tool that clutch off was a little over 10000 miles. Of course cats only need their pulled every 1500-2000 miles for new pins and arms
  #133
Old 03-05-2014, 04:05 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Definitely sounds it
  #134
Old 03-05-2014, 04:06 PM
fordpower88's Avatar
fordpower88
fordpower88 is offline
Afternoon guys!
  #135
Old 03-05-2014, 04:24 PM
DieselCamper01
Hey Troy...
Quick Reply: March is more winter! BS thread
