Minnesota Chapter Join Chapter, Leader: fordpower88
March is more winter! BS thread
Old Mar 5, 2014 | 11:40 AM
  #121
DieselCamper01's Avatar
DieselCamper01
I didn't know that was even possible Chris.
Old Mar 5, 2014 | 11:54 AM
  #122
dlibson's Avatar
dlibson
Do you have a clutch puller Jay?
Old Mar 5, 2014 | 11:56 AM
  #123
dlibson's Avatar
dlibson
Only by an admin or moderator...
Old Mar 5, 2014 | 12:43 PM
  #124
DieselCamper01
Yes I do.
Too funny they would even bother. LOL
Old Mar 5, 2014 | 01:28 PM
  #125
dlibson's Avatar
dlibson
I will have to borrow that someday then.
It is odd. But some people have little better to do...
Old Mar 5, 2014 | 01:58 PM
  #126
DieselCamper01
Any time Dave.
Old Mar 5, 2014 | 02:30 PM
  #127
wildstang's Avatar
wildstang
VT Chapter Ldr
Not sure if the Yamaha clutch bolts are similar to some of the skidoos but if so you could use the water method. I've done this to take the clutches off mine. Pull clutch bolt out, lay sled on side, put some water into hole, wrap the bolt threads with that Teflon pipe thread tape, more at top as you wrap it towards end of bolt (stopping at the end of the threads of course), thread bolt in and tighten. Doesn't take much force and it pops it off. Hydraulic pressure.
Old Mar 5, 2014 | 03:33 PM
  #128
DieselCamper01
That is another way Jim but why not just use the right tool for the job?
Old Mar 5, 2014 | 03:44 PM
  #129
wildstang's Avatar
wildstang
VT Chapter Ldr
Because I don't want to spend $50-70 on one that I may use every 2-3 years maybe and more apt to break or screw up the threads. Takes very little force using the water method. Cheap and it is easy
Old Mar 5, 2014 | 03:50 PM
  #130
MisterCMK's Avatar
MisterCMK
If you had purchased a quality American Made sled such as Arctic Cat you wouldn't have to work on it that often...
Sent from my Telegraph using IB AutoGroup
Old Mar 5, 2014 | 04:00 PM
  #131
DieselCamper01
I bought mine back in the 80's when I bought my Phazer. It worked on that, the Vmax, the SRX, Daves SX. Money well spent.
Old Mar 5, 2014 | 04:04 PM
  #132
wildstang's Avatar
wildstang
VT Chapter Ldr
Your probably right. The 05, the first time I tool that clutch off was a little over 10000 miles. Of course cats only need their pulled every 1500-2000 miles for new pins and arms
Old Mar 5, 2014 | 04:05 PM
  #133
wildstang's Avatar
wildstang
VT Chapter Ldr
Definitely sounds it
Old Mar 5, 2014 | 04:06 PM
  #134
fordpower88's Avatar
fordpower88
Afternoon guys!
Old Mar 5, 2014 | 04:24 PM
  #135
DieselCamper01
Hey Troy...
