Mine didn't come with them, I think the PO removed them. What I did was go to McDonalds every few days and supersize and made sure to get the biggest shamrock shake they would sell me. I now weigh over 700 pounds and I am able to keep the front end of my EX on the ground. On the freeway before I was lifting up at around 35mph and it scared the ***** out of the wife!
Er, um, maybe I should ask the question on Monday...I guess it's like a "henway"...
My guess if a 4x4 V10 was on 4 scales:
LF = 2350 lbs
RF = 2350 lbs
LR = 1400 lbs
RR = 1400 lbs
I"m looking at a couple of spring charts and want to estimate where I'll be in the "spring". Too close to the auxillary spring and the ride will be bad.
LF = 2350 lbs
RF = 2350 lbs
LR = 1400 lbs
RR = 1400 lbs
Make sense?
Come on guys , how much clearer could he have made it..
No kidding! I knew what I was asking for! Seriously, I thought "corner weight" was a common term and not comedic fodder. At a minimum, glad I could provide some fun.
Is it even possible to adjust the suspension to balance the weight at each corner?
Yes, simply increasing or decreasing the air pressure in a tire or placing a small spacer under a spring will dramtically increase or decrease corner weight but to what end.
He's using the wrong terminology. Corner weight is a racing setup term measured using a scale under each tire as seen in these pictures.
OK now I'm really confused is there actually a corner weight?
Technically yes but no one with a street car measures it nor do they measure rake, cross weight, %front/rear, stagger, etc.... because it's effect is minimal. Put simply, it's a setup term used in racing where a scale is placed under each tire on a perfectly level platform and the car weight is measure at each corner. It's easily adjustable and can make an enormous handling difference on a race track with a properly setup race car.
