High Idle problem
Old May 23, 2002 | 09:16 PM
cajunbronco's Avatar
cajunbronco
High Idle problem
Old May 24, 2002 | 11:06 AM
timberbuck's Avatar
timberbuck
High Idle problem
I have an 89 f-150 5.8L 4X4 that idles at 3000+ until I pull the plug in the IAC control, then it idles fine. I have left it unplugged, but it causes it to run rough while it's cold. I have cleaned the IAC and there is obviously power to it (about 10v). The resistance across the solenoid is about 11 ohms. I'm guessing the IAC is not the problem. Any ideas?
Old May 24, 2002 | 12:09 PM
timberbuck's Avatar
timberbuck
High Idle problem
I probably mis spoke about the IAC. I meant the Air Bypass Valve. Additionally, on a cold start, the engine idles at about 1000 until it warms up, then it jumps to 3000+!
Old May 24, 2002 | 12:22 PM
mantta's Avatar
mantta
High Idle problem
It sounds like you have a vacuum leak somewhere. I would check all the vacuum hoses, the EGR valve and run a KOEO test.
Old May 28, 2002 | 08:43 AM
timberbuck's Avatar
timberbuck
High Idle problem
Thanks, I ran the codes and found a voltage out of range problem with the throttle position sensor. Changed it out and everything is fine now!
