1966 - 1977 Early Broncos
automatic column
Old Jun 30, 2003 | 11:35 PM
7296ford's Avatar
7296ford
automatic column
i would like to know if you have to have an actual bronco automatic steering column for a bronco or can you use one from a early model pickup and it be just the same.
Old Jul 1, 2003 | 12:03 AM
RCrawler's Avatar
RCrawler
automatic column
The column for an EB is unique. And there is also differences in different years.
But, it is a popular upgrade for a late 70's, early 80's pickup or van tilt column. You need to change the underdash mount and build your own shaft. You can also use the original column shift from the pickup.
There are also a couple of aftermarket GM type tilt columns that will bolt in. They are brand new columns and work great in the Bronco. I have installed a couple of them in the past. Great quality, better electrical system, and the column design itself is much better than the OE Ford IMO.
