Where are your Gauge/Gauges
Im using a relays to switch between pre/post turbo with the upper glowshift & fuel pressure/coolant pressure with the lower gauge.
If I could only have one set of gauges...I would get the edge insight or the scan gauge(much cheaper...but not as pretty). You just can't beat the versatility and ability to look at various functions that allows you to do some troubleshooting.
Troubleshooting may not sound like your cup of tea, but when you have an issue, the projections and calculations the scan/insight is able to provide aids your mentor(from the 6.0/7.3 forum) to tell you what's going on inside your engine!
Why are those darn pyro gauges so expensive? Jeez!
What, by opinion, are the best quality gauges? I had Banks in my dually and they were fine....boring, but fine. I was thinking about 2 pyros (or a single with a switch), boost and trans temp. If I go with a single pyro I may add either EOT or fuel pressure. Recommendations??
Autometer Under Dash Console - Riffraff Diesel Performance
EDIT: I think I bought my pod from Strictly Diesel, as I also got the fuel pressure hose extension at the same time.
http://www.strictlydiesel.com/c-37-g...or-mounts.aspx
Are the ect and eot electric sensors or manual?
