Help !!!!!
Old Feb 24, 2014 | 07:10 PM
ATE88's Avatar
ATE88
Help !!!!!
I have an 89 f250 302. Went to get gas today and it wouldn't start. I'm getting spark and fuel. I pulled off the dist cap and sanded all the terminals and the tip of the rotor. I changed the fuel filter just incase and still nothing. I just got back from holidays so its been sitting for a week and half was running perfect when I left. I havent had an issue with weather before but it's about 0 celcius and we just got 8 inches of snow. Not sure if that would effect it or not.
I'm stumped any help would be great. I need the truck for work tomorrow morning!!!
Thanks
Old Feb 24, 2014 | 09:25 PM
skyfox10's Avatar
skyfox10
What have you done to verify spark and fuel?
If there is fuel flow, have you been able to check fuel pressure?
Also, when you say "Went to get gas today and it wouldn't start." and " I just got back from holidays so its been sitting for a week and half was running perfect when I left." Does this mean that it died after driving it to the gas station, or that it was fine, sat for a week, then you went to start it after the week long sit, and it would not start?
Old Feb 25, 2014 | 09:09 AM
DAT2109's Avatar
DAT2109
Does the engine turn over?
If you have spark at the plugs, then it would usually be fuel or compression. Are the plugs wet when you pull them out?
Old Feb 25, 2014 | 09:57 PM
ATE88's Avatar
ATE88
After the week long sit it would not start. Was running perfect when I left. I pulled a plug and saw it spark when I turn it over. Changed the fuel filter ad had plenty of gas coming out also pushed the valve on the fuel rail and had lots spray out so plenty of pressure. Still can't start and after work today I tried again, still nothing and now I think my starter relay went again because it stopped turning over but still turns if I jump the terminals on the relay,... Just replaced relay again a couple months ago.
Also yesterday it did start to fire briefly and just barely ran for about 5 seconds then backfired and hasn't even started to fire since.
Old Feb 25, 2014 | 09:58 PM
ATE88's Avatar
ATE88
Didn't check If the plug was wet but smelled strong of fresh gas
Old Feb 25, 2014 | 10:00 PM
ATE88's Avatar
ATE88
Also my ignition has been really hard to turn in the cold weather, any change the switch could
Be at fault??? Or would it not turn over at all??
Old Feb 25, 2014 | 10:19 PM
Bruners4's Avatar
Bruners4
I changed out my ignition switch because it was so stiff that I was afraid of breaking the tang off the Ignition Lock Cylinder again. I also had trouble with it sticking in the start position.
After cranking the engine for a while and it not starting, do you smell fuel in the tail pipe(s)?
Old Feb 25, 2014 | 10:23 PM
ATE88's Avatar
ATE88
Yes I did smell fuel at the tailpipes
Old Feb 25, 2014 | 10:30 PM
Bruners4's Avatar
Bruners4
I would verify that the timing chain hasn't jumped. turn the engine to TDC #1 and check the timing mark. It should line up. then remove the dist. cap and see where the rotor is pointing, it should be #1. Also check if you can if the little window of the dist timing ring is lined up with the trigger under the rotor. This is what sends the signal to the computer to trigger the coil to fire.
Old Feb 25, 2014 | 10:46 PM
ATE88's Avatar
ATE88
Ok thanks I'll take a peek
Old Feb 25, 2014 | 11:32 PM
ATE88's Avatar
ATE88
Ok I just need a reminder, it's been a while since I've done this. To set #1 at tdc I should be able to set the 0 on the harmonic balancer to the pointer shouldn't I ???? Because I did that and it was showing nearly 180 degrees out which could t be right, what am I doing wrong???
Tomorrow I can grab m timing light and try that too but for now I don't have it with at home.
Old Feb 26, 2014 | 12:31 AM
88n94's Avatar
88n94
You are not doing anything wrong. You have to turn the engine over twice to get the rotor to make one complete revolution. The rotor drives off the camshaft, and the camshaft only makes one revolution for every two revolutions of the crankshaft. If you turn the engine(crankshaft) over one more turn the rotor will be pointing at the #1 position on the distributor cap.
Old Feb 26, 2014 | 01:09 AM
ATE88's Avatar
ATE88
Oh ya... Like I said its been a while haha
Thanks
Old Feb 27, 2014 | 09:51 AM
ATE88's Avatar
ATE88
Thanks for all the help !! My truck randomly started last night and so far it's still starting, but it doesn't want to when cold. I think it might Just have moisture in the fuel so I filled it up and put in sea foam. I can get to work now but when I hit the gas it almost dies and backfires, it's never done this before so I'm hoping it's just moisture. Does that sound right??
Old Feb 27, 2014 | 10:15 AM
Toplait's Avatar
Toplait
Could put some Heat in the gas tank. They sell it at your local Wal-Mart
-Or-
Could that be a Throttle Position Sensor problem? I think it is... Might want to check for codes
Art5
1978 - 1996 Big Bronco
Jun 15, 2014 08:00 PM
beave1976
15
Jan 6, 2006 09:48 AM
lg1
15
Nov 28, 2005 06:57 PM
irishguyincc
1983 - 2012 Ranger & B-Series
29
Aug 18, 2005 12:20 AM
mcal
Jan 7, 2003 09:00 PM
