Anybody have the GTP38R
Wouldnt the map change with a different compressor wheel (billet ported wheel)? It's not a stock turbo anymore. These arguments sound like similar ones from the weight police saying an F350 maxes out at 9900 GVWR on the sticker, regardless of the modifications to the suspension, etc.
I wonder if Clay would have the map on a turbo modified with a ported housing and his ported compressor wheel. I might have to give him a call.
Man, that's great - that's a young truck. The stocker is a good turbo, and the GTP38R is good as well. This pieced together turbo upgrade I'm clammering about is because I already invested in the ported compressor housing, and have a 1.0 turbine housing on the bench. Small cost for me to add a billet compressor wheel and go. For you, a ready-to-go bolt-on might be better. Good luck with this.
Jason, I love you man..... buuuuuut that just doesn't make sense.
Your restrictions are the intercooler and the heads. Boost numbers are not a measurement of restriction with regards to the turbo. The entire point of a turbo is to pack more air into the same space, which of course increases what the boost gauge reads.
Turbos flow air and create heat. How efficiently they do it depends on their MAP. Generally the more efficient ones also tend to achieve a higher boost number because they are actually flowing more air and doing their job, and that air is only going in one direction.
Or if you are just way beyond the MAP and creating that much heat.....
But you should see a common theme with my post...... MAP!
I am tired tonight so I won't be able to do some research to bett explain myself, but I will in the near future.
Noticed a recent review on Clay's site under the billet wheel for ported housings:
Posted by Dave on Feb 23rd 2014
I ordered this along with a new Center Cartridge. My boost is up by 4 psi and I have a quicker throttle response. Thank you for another great product.
4 psi more and quick spoolup would be a nice gain, if the stocker can handle it. Would Clay sell it if it could not?
Anyone know this "Dave"?
I am running a 38R and it is a fine option. My truck already had bellowed uppipes or I would have used one of the T4 mounts and turbos available for Irate Diesel or DP Tuner. They are more efficient and offer a greater ability to grow as you build your truck.
If you are looking for an easy drop-in, you can't deat a 38R.
on
I replaced my 38R last year with about 60k miles on it due to oil smoke. I had some wear metals show up in my UOA and was tired of chasing the smoke problem. It was more prominent in cold weather and even spit oil at the turbine outlet connection at times. After its replacement, the levels dropped to more normal readings. Switching back to Rotella 15w-40 dino also helped with the oil improvements. Garrett had some tooling issues back in '09 when I purchased mine. I tried to get a replacement center cartridge, but none was offered for the 38R. Clay helped we me out with getting a new complete turbo replacement and I added his RR 11 vane billet compressor wheel at that time. I love the compliment the wheel gives to the 38R. I later changed back from a 1.15 turbine housing to the 1.0 with a cross drilled plenum wall. I really love how all this plays well together and I have seemed to have found a "sweet spot" with this combination.
#28
The van turbo is pretty much a direct bolt on. Don't get too caught up in boost numbers. They are misleading, Jeff. They are a measure of restriction, not flow. The big thing about turbo's and any forced induction is, you want flow not restriction, and boost numbers are really a measure of the air stacking up in the intake side. Bigger peak boost numbers look nice, but flow is really what you are after. A bigger flowing turbo with lower boost numbers will out perform a less efficient one with higher boost numbers.
Pressure, in this case boost, is a measure of restriction. But I'm having trouble with this:
I think I get the drive pressure being different.
Help my feeble mind grasp this.
#29
#30
Well you would think it should last more then 60K. It sucks Roland had to replace his that early but IMO I think if they made them rebuild-able they would sell more. I hope they got the tooling issue figured out because I would like to get one down the road.
