390 Short Block
Old Feb 22, 2014 | 09:07 PM
chinoz71's Avatar
chinoz71
390 Short Block
Hi All,
I found someone selling a 390 short block that the owner claims to have had all machine work done on and it is just sitting in his garage because he sold the vehicle that he was going to use it on. I have not seen it yet but he said the only bad thing is that it had been bored .060 over and has flat top pistons. Is this really a bad thing? i know that this will not leave anymore room for future boring if needed. I am planning on using my 360 heads on this block. He also told me it has a medium cam in it? What should i look for and how can i identify what I am looking it so I do not run into any pitfalls? Casting numbers? Tell tale signs that something may be fishy?
Thanks Guys!
Old Feb 22, 2014 | 11:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by chinoz71
Hi All,
You cannot go by casting numbers or date codes on the engine to ID it, because...
1968/76 360/390 block is the same, has the same bore 4.05."
The only difference is the stroke: 360: 3.50" / 390: 3.78."
On sale day, 360 engines magically become 390's!
1958/64 FE engines were only installed in cars, have a different bolt pattern on the block where the rubber insulators attach than 1965/76 FE engines.
travelerest
47
Aug 30, 2010 09:01 PM
biggut
15
Nov 8, 2005 03:10 PM
78fordman
Jan 29, 2004 05:57 AM
carrojp
23
Feb 21, 2003 01:34 PM
