97 7.3 programmer ?
Old Feb 22, 2014 | 05:29 PM
martins2141's Avatar
martins2141
97 7.3 programmer ?
I am looking at an older EDGE EVOLUTION programmer for my 97 7.3 power stroke, are these any good? do they help gain MPG? can pick it up for 150 bucks.please help if you can THANKS
Old Feb 22, 2014 | 06:00 PM
Splatts's Avatar
Splatts
Save your money, and get some good quality tunes, they are worth it.
fordpride's Avatar
fordpride
I wouldn't run the edge. They are known for messing up the PCM
For that price it would be good for reading codes and having the gauges
Old Feb 22, 2014 | 06:07 PM
martins2141
Thanks guys, have you seen the you tube videos of the guy in Georgia, power stroke help.com? he suggests the SCT tuner, what do you think of that one? I don't mean to sound dumb, but I need to keep it simple.lol
Old Feb 22, 2014 | 06:09 PM
martins2141
I did order a k&n air filter and mbrp 3" down pipe that should help with MPG I hope,I have already deleted the cat and I may delete the muffler,not sure if it will be too loud.
Old Feb 22, 2014 | 06:18 PM
stainlessstroker95's Avatar
stainlessstroker95
Stay away from k and n. They are know to dust turbos You can get a 6637 setup for a whole lot cheaper. For tunes most use a ts style chip and get costume tunes burned on it. For in cab gauge to read what the pcm can see and pull codes, a scan gauge is a good option. But the you will need others like trany and egt as the pcm does not read those. Stay away from the power stroke help guy.
Old Feb 22, 2014 | 06:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. K&N filters you are buying a name only. the filter is inferior. i think the stock filter is actually better than a K&N filter.
SCT is for the 6.0 engine.
for the 7.3 i would recomend a DP tuner.
and don't bother with powerstroke help dot com dude.
bill sells his business with a whole lot of BS that is not needed.
Old Feb 22, 2014 | 06:35 PM
martins2141
what is this 6637 set up, who makes it?
Old Feb 22, 2014 | 06:46 PM
stainlessstroker95
Riff raff diesel. I would post a link but im on my phone.
Old Feb 22, 2014 | 07:14 PM
fordpride's Avatar
fordpride
6637
Riffraff Diesel 6637 Filter Kit - Riffraff Diesel Performance
Old Feb 22, 2014 | 09:47 PM
stainlessstroker95
Thanks Mike.
Old Feb 22, 2014 | 11:42 PM
BBslider001's Avatar
BBslider001
PCM does read the trans temp but not EGTs.
Old Feb 23, 2014 | 12:09 AM
stainlessstroker95
Are you sure?
Old Feb 23, 2014 | 08:50 AM
fordpride's Avatar
fordpride
Yes the PCM reads trans temp
Old Feb 23, 2014 | 10:15 AM
BBslider001
Are you sure?
Well, I get my Edge Insight tomorrow so I will let you know. Madpogue and an Edge rep assured me this is how it reads trans temp, so I am thinking it is correct. The only external sensors needed with the Edge anything is an EGT probe. I hope this is all true as well.
