squealing pulley help
Old Feb 22, 2014 | 10:50 AM
flavo's Avatar
flavo
The truck started squeaking at me last week. I found what appears to be a loose pulley of some sort. It's wobbling a little so I assume that is the problem. It's the second pulley down on the passenger side. The red pointer is where the wobbling is coming from. What needs fixin here?
Thanks so much
free image hosting
taking a screen shot
Old Feb 22, 2014 | 11:29 AM
takotruckin's Avatar
takotruckin
That is the tensioner. It is spring loaded and keeps the belt tight. A little play there is OK, too much is not OK. could you take a video of the wobble?
Old Feb 22, 2014 | 11:37 AM
Supercab's Avatar
Supercab
With any kind of miles I'd recommend just replacing the whole tensioner assembly.
It will have nice tight springs and new pulleys and bearings!!
Also, if it were mine I'd change the belt while you are at it!
Old Feb 22, 2014 | 12:41 PM
AMG-SM's Avatar
AMG-SM
That is a wear item. might as well replace the tensioner assembly and belt while you are there as supercab mentioned.
Old Feb 22, 2014 | 12:57 PM
fbh31118's Avatar
fbh31118
If your on a tight budget you can just unbolt the pulleys and replace those alone. Seems like you can purchase generic pulleys for ten or fifteen bucks a piece. There's just one bolt in each and it only takes a few minutes a pulley once the belt is off.
Old Feb 22, 2014 | 01:08 PM
flavo's Avatar
flavo
Hmm, I went and took a video but the wobbling can't be seen in it. I didn't realize that some movement was OK. I might just go ahead and replace the whole thing anyway if the pulleys are going. It's squaking pretty good and the motorcraft version is $78 shipped on Amazon unless I hear of a better value from someone on here.
Can I test the pulleys to make sure they are bad before I buy a new unit? Maybe spray some some PB Blaster in there?
Old Feb 22, 2014 | 01:12 PM
flavo's Avatar
flavo
<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v8.tinypic.com/player.swf?fil...s=8"><br><font size="1"><a href="http://tinypic.com/player.php?v=zlrqsj&s=8">Original Video</a> - More videos at <a href="http://tinypic.com">TinyPic</a></font>
the hoster blue the size out all weird. But you can hear if it you please.
Old Feb 22, 2014 | 01:16 PM
flavo's Avatar
flavo
having technical difficulty with the photo hoster. carry on.
Old Feb 22, 2014 | 01:41 PM
takotruckin
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
It sounds to me like it is a belt problem. With the engine running spray the belt with a little water and see if it shuts up for a second. I would pull the belt and check the tensioner pulleys, idler pulley and water pump for any excessive play before installing a new belt though.
I had a morning squeak on my truck. The belt was a Gates that was almost 2 years old, so I put a new tensioner and idler pulley on it since they had some play, also fixed my leaking thermostat housing. The noise was worse the next day, it didn't go away any more once it warmed up. A new belt and she is back to her quiet clattering self!!
Old Feb 22, 2014 | 02:01 PM
Pikachu's Avatar
Pikachu
RockAuto has the tensioner assembly for $46 for a Dayco, through $77 for a Motorcraft, with several other brands and prices in between.
Old Feb 22, 2014 | 02:18 PM
flavo's Avatar
flavo
takotruckin
thanks to your misfortune all I need is a new belt. Which is unfortunate because I just replaced the old cracked one less then a year ago.
The water made the squeal go away.
Old Feb 22, 2014 | 02:36 PM
takotruckin
Originally Posted by flavo
takotruckin
I am seriously disappointed in aftermarket belts. Mine lasted almost 2 years and 20k miles. My 01 Expy has the OE belt with 230k on it with no noises.
Yours looks like a Gates belt as well, I believe they have a lifetime warranty against defects, would be worth looking into. I work in a shop, so I just warrantied mine out with my vendor.
Old Feb 22, 2014 | 02:58 PM
Franko72's Avatar
Franko72
Molon Labe
Depending on how many miles are on your truck I would go ahead a replace the tensioner unit.
My friends tensioner on his 7.3 just broke going down the road. When it breaks it's a small explosion. There is a tightly would spring in that unit. His truck had to be towed.
The spring in mine was getting weak and I ended up shredding two belts after gouging on the go pedal to pass slow traffic.
I think I paid around $50 for mine at Autozone. Not my favorite parts house, but it's been holding up for almost two years now.
Old Feb 22, 2014 | 07:39 PM
t.scottNDU's Avatar
t.scottNDU
The tensioner doesn't seem to be one of those "Motorcraft-or-nothing" parts either. I'm starting to find that Motorcraft tensioners for these trucks seem to be lesser quality, or don't hold up as long as certain aftermarket units.
Old Apr 5, 2014 | 03:04 PM
caedo's Avatar
caedo
One of the pulleys ate itself this morning. Should I go Motorcraft? Or what is the suggested aftermarket alternative?
