orange peeling
Old Jun 30, 2003 | 03:17 PM
Devin 123
Guest
Posts: n/a
orange peeling
i just put a coat of paint on my fender and like a minuite later it started to get a bunch of ridges in it is it because it wasnt wased right and it was mixed right because it came premixed.
Old Jun 30, 2003 | 09:13 PM
Aekisu's Avatar
Aekisu
orange peeling
I'm not sure if you are asking a question or making a statement. I will assume, asking a question.
What kind of paint did you spray?
Was the surface bare steel or did it have paint on it?
Old Jul 1, 2003 | 09:37 PM
Ironbelly's Avatar
Ironbelly
orange peeling
What kind of prepwotk did yoy do?
Old Jul 17, 2003 | 04:32 AM
Scooter29's Avatar
Scooter29
orange peeling
Orange peel is caused by mis-matched paints. You can't apply an acrylic over enamel or enamel over oil. Auto paints these days are preety specific. You also need to use compatable primer. Good luck....
Old Jul 17, 2003 | 06:32 AM
Huntsman's Avatar
Huntsman
orange peeling
Orange peel is most likely not the priblem, since it is most likely caused by poor atomization from the spray gun or incorrect hardeners.
If it looked good when sprayed, THEN wrinkled up it could be from incompatible paint/primer products OR inproper prepping. Another possibility would be not waiting the correct time between coats of paint.
If you sprayed a fender without priming first then applied only one coat of paint, it most likely is incompatible paint.
Everthing is so high-tech these days you have to practically be a chemist if you deviate from the instructions.
Old Jul 17, 2003 | 06:56 PM
Scooter29's Avatar
Scooter29
orange peeling
I hear you there Huntsman. I am so used to spray cans, I wouldn't know where to begin with a decent set-up. It's a good thing I don't expect much from myself, when it comes to exterior painting!! HEE HEE... I'd rather have the GO, than the SHOW! It's hard to get a good look at a vehicle when it's moving like a bat outta @*#$!! Talk to you guys later....
Old Jul 18, 2003 | 09:58 PM
2Wise4aGM's Avatar
2Wise4aGM
orange peeling
I always heard that orange peel meant that the paint dried too fast? Any truth to this?
Thanks, Mark
