Full Bullet Proofing. Missing Anything?
Old Feb 21, 2014 | 10:23 AM
zeppelingto's Avatar
zeppelingto
So working on a early 2004 6.0 with 160,000 miles.
Installing:
ARP headstuds
OEM head gasket kit
ASE EGR delete
Cat delete
Ficmrepair.com lifetime FICM with Atlas 40
High pressure oil pump
Blue spring kit
Scan guage
Am I missing amything? Should I install new push rods?
Old Feb 21, 2014 | 10:30 AM
9228.bobcat's Avatar
9228.bobcat
Installing:
ARP headstuds
OEM head gasket kit
ASE EGR delete
Cat delete
Blue spring kit
Scan guage
I would replace the pushrods while your in there. Go with the 6.4 pushrods. Whats the reason for the hpop? Also would flush with vc9 and water before the work is done and put in cat1 coolant along with a coolant filter.
Old Feb 21, 2014 | 10:34 AM
9228.bobcat
Just seen your other threads. I see why your replacing the hpop.
Old Feb 21, 2014 | 10:49 AM
zeppelingto
This is actually a different truck than the HPOP I just did. I just figured these early 6.0 go through pumps enough that I'm in here I'm gonna replace it.
Here are some pics of where I'm at so far.
Old Feb 21, 2014 | 03:05 PM
Carolina Rig's Avatar
Carolina Rig
I'd do an oil cooler just because you're in there and it's easy at that point.
How are the injectors? Maybe polish the spool valves.
Water pump??
Old Feb 21, 2014 | 03:28 PM
zeppelingto
Sorry forgot got 8 new oem injectors and new oil cooler. Water Pump is a good idea. Do the 6.4 pushrods drop right in? That's the first time I've heard that.
Old Feb 21, 2014 | 09:48 PM
bodywerks's Avatar
bodywerks
If you want to truly bulletproof, then ditch the OEM oil cooler and oil filtration system and go bulletproof desel air/oil cooler.
BigBlueX
Sep 5, 2015 01:53 PM
run6.0run
Jan 31, 2013 12:47 AM
Hand Clutch
Mar 3, 2011 07:44 AM
big poppa
37
Jan 15, 2011 07:14 AM
WishIhada7.3
Mar 22, 2009 09:45 PM
