Found someone selling a factory installed integral AC setup from a 77 F100.
Can it be moved into my 72 F250?
No, 1973/79 A/C is completely different, will not fit. 1968/72: A/C bezel bolts to bottom of dash. 1973/79: A/C components are located behind dash.
The only thing these two different A/C systems have in common: Factory installedintegral A/C is combined with the heater, the A/C controls are located in the same panel as the heater controls.
Left: 1968/72 / Right: 1973/75, 1976/79 is very similar.
