Sponsored by: Auxito
Airbag Light Error Code
Old Jun 30, 2003 | 12:19 PM
Bob Hunter's Avatar
Bob Hunter
I just had my 99 F-150 supercab inspected via the new OBDII system. Now(same day) the Airbag light is flashing an error code 2 7. Any idea what the code means and how to reset the system. I hate to think that the inspection station messed the SRS up but man what a coincidence.
Any help is appreciated,
Bob
Old Jul 1, 2003 | 01:26 AM
Racerguy's Avatar
Racerguy
Hi Bob and welcome to FTE
The Light Flashout Code 27 means a problem with the passenger's airbag disable switch.
You can probably clear the code by pulling a battery terminal off for a few minutes. If the light starts flashing again you'll need to get the system scanned. There are 2 different trouble codes for a LFC 27.
I cant think of any way the inspection station could have made the light come on.
Old Jul 1, 2003 | 05:58 PM
Bob Hunter's Avatar
Bob Hunter
Hello Racerguy!
Thanks for the prompt reply. I pulled the switch out today and the light bulb is indeed blown. Any idea what type of bulb to put back in. Looks like a pretty simple circuit but I don't want to start drawing too many amps through it.
Thanks again!
Bob
"There are 10 types of people in the world. Those who understand BINARY and those who don't"
Old Jul 1, 2003 | 06:30 PM
Racerguy's Avatar
Racerguy
I really dont know what type of bulb it would use as I've never had a PAD switch apart and I dont think that Ford sells the bulbs for them. I would guess it would be something like a radio illumination or headlight switch illumination bulb. It probably wouldn't be a big deal to just replace it with whatever fits and then see if it works ok.
Old May 16, 2009 | 08:58 PM
rcdriver11's Avatar
rcdriver11
What are the 2 trouble codes for the LFC 27 I have seen lots of posts that say the PAD light is burned out. What could be the other
