oil cooler
Old Jun 30, 2003 | 10:42 AM
dorymate88's Avatar
dorymate88
oil cooler
I would like to put an oil cooler in my 89 f150 300. Doesnt look like many places to plumb the bugger in.Suggestions would be most appreciated!Thanks
Old Jun 30, 2003 | 12:24 PM
steve83's Avatar
steve83
oil cooler
You have to buy an adapter and rig up your own plumbing. Jeg's & Summit sell the stuff, but they don't cater to the I-6, so you won't find the parts listed for it. Since the 4.9L uses the same oil filter and has a LOT more room around it than the 5.0L & 5.8L, those adapters will work.
Old Jun 30, 2003 | 04:09 PM
javi2001's Avatar
javi2001
oil cooler
You also can obtain/install a separate oil cooler using a "T" brass connection at oil press sender to obtain oil from engine and returning directly to a drilled hole on engine block. A few hoses and that's it.
Regards;
