Twin I Beam
Old Feb 22, 2014 | 10:14 AM
  #31
redman84's Avatar
redman84
Originally Posted by BBslider001
I am right here in the same boat with you Glenn trying to decide whether or not to do them myself. I am heavily leaning towards just letting them have at it and be done with it. I got quoted right at the same price for those bushings, but I also need radius arm bushings as well as 3 of 4 ball joints. Guess it was my turn eventually! I am like Aaron was in another thread and ready to give up, but I know it's worth it down the road.
Aaron was ready to give up huh? Well I personally think he should and then sell me his truck crazy cheap out of spite for it. j/k
As much as you need done I think you're looking at a pretty sizeable tab. That's a lot of work but if you put in high quality ball joints, bushings, and maybe do the bearings while you're in there then the front will be ready to ride for another 100k miles short of greasing. Good tie rods are nice too but as easy as they are to swap doing it more often isn't such a big deal to pinch some pennies. Just don't cut corners on the bearings, ball joints, and grease or you will be doing it again far too premature.
Old Feb 22, 2014 | 11:37 PM
  #32
fordman67's Avatar
fordman67
easy there..im not giving up..just have to get motivated again.
get er done byron!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 6, 2014 | 08:49 PM
  #33
oldbird1965's Avatar
oldbird1965
OK, today I got the pivot bushings installed on the twin I beam. Radius arm bushings were good, tie rods were good. But, he tells me my springs are depressed and need new ones? He recommends 'Moog cargo coil springs progressive rate'. He said the problem is, they don't make them anymore. I did some looking but couldn't find any. Any body have any recommendations?
Old Mar 6, 2014 | 08:55 PM
  #34
ReBilld's Avatar
ReBilld
I always thought your truck kinda nosed down in the front, but figured it was the fender flares that just made it look that way. I don't have any recommendations for springs, but I'll help you look.
Old Mar 6, 2014 | 09:02 PM
  #35
ReBilld's Avatar
ReBilld
Found these. There is a heavy duty and extra heavy duty. Don't know anything about them though. Heavy Duty Front and Rear Coil Springs for Ford Pickups and Vans
Old Mar 6, 2014 | 09:10 PM
  #36
farmert's Avatar
farmert
I have bought rear leafs from these guys, the best piice I found. 1992-2000 Ford E350 - HD Coil Springs (Pair) - 350-1200SD | $127.60
Edit OOPs wrong springs these should work http://www.sdtrucksprings.com/index....roducts_id=401
Old Mar 6, 2014 | 09:13 PM
  #37
oldbird1965
Thanks Bill, your quick! I guess you have to call to get a price unless I missed something. What do you suppose he meant be 'progressive' rate. Part of the spring is weaker and the other part is stronger?
Old Mar 6, 2014 | 09:14 PM
  #38
ReBilld's Avatar
ReBilld
Tom, those are for an E350. The F350 ones are a few dollars more. 1980-1999 Ford F350 - HD Coil Springs (Pair) - 351-844SD | $134.27
Old Mar 6, 2014 | 09:16 PM
  #39
ReBilld's Avatar
ReBilld
Nevermind...you caught it! LOL!
Old Mar 6, 2014 | 09:17 PM
  #40
oldbird1965
Thanks Tom, I added it to favorites.
Old Mar 6, 2014 | 09:23 PM
  #41
oldbird1965
Think the heavy duty ones are better? Probably.
Old Mar 6, 2014 | 09:24 PM
  #42
farmert's Avatar
farmert
Ya, I was looking at the weight rating, and thought the first ones were for the diesel engine, never saw that they were for the E series until I posted them.
Old Mar 7, 2014 | 07:50 AM
  #43
fordpride's Avatar
fordpride
When I changed the one on my 97 I got them from the dealer.
That was in 09-10
Old Mar 7, 2014 | 04:59 PM
  #44
oldbird1965
I went ahead and ordered these: 1980-1999 Ford F350 - HD Coil Springs (Pair) - 351-844SD | $134.27 Thanks Tom
They are rated 500 lbs above stock. The ones you listed Bill are really heavy duty, the guy told me they were for commercial vehicles. The alignment guy said I shouldn't go with too heavy of a spring. The Ford dealer said that they have been discontinued, go figure.
Old Mar 18, 2014 | 06:40 PM
  #45
oldbird1965
Wow, I like it!! The new coil springs raised it up 3" but he said it will settle. Wants me to bring it in after a month to check the alignment after it settles. I really like the way it sits now, not as much rake as before. Now, Before and after.
