5.8L Smog Pump Delete with Pics
Old 11-28-2015, 09:52 PM
fordbozo's Avatar
fordbozo
fordbozo is offline
My smog pump was starting to make death bearing howling noises. It had been disconnected by the previous owner anyway. The local Orielly's let me try a few belts on in the parking lot. I forgot which one I ended up using. My 351W looks way different, but simply short belting it proved very straight forward.
Oh, and we are in the sticks so no DEQ nonsense for any of my vehicles, thank flying spaghetti monster. None of my cars can make it through.
  #32
Old 09-22-2016, 05:04 PM
ttrapasso17's Avatar
ttrapasso17
ttrapasso17 is offline
Old thread I know. I was hoping someone knew the part number to the a.c. idler pulley that was used so you don't have to but a shorter belt ? Thanks.
  #33
Old 09-22-2016, 05:28 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
When I am looking for a part, I usually use summit racing. You can find the a/c delete pulley there.
  #34
Old 09-22-2016, 07:42 PM
ttrapasso17
And they should have just the pulley? Everything that kept pooping up was the pulley and the bracket.
  #35
Old 12-20-2016, 11:44 AM
mramc1's Avatar
mramc1
mramc1 is offline
This is the part from RockAuto. DAYCO 89013
  #36
Old 06-01-2017, 02:54 PM
rb_weaver's Avatar
rb_weaver
rb_weaver is offline
Thumbs up 3 years belated thanks!
I just wanted to say thanks for the write-up and pics...3 years later.
I'm now doing this to my 96 F-350 5.8L.
Much appreciated.
Semper Fi
Brandon Weaver
  #37
Old 06-01-2017, 06:05 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
Much appreciated.
Semper Fi
Brandon Weaver
Wait a minute, you searched and found a writeup pertaining to what you want to do and that was it????
You're supposed to ignore the dozens of helpful threads that provide the exact info you're looking for and start a new thread asking the same questions! Duhhhhh.
  #38
Old 06-05-2017, 07:12 AM
rb_weaver's Avatar
rb_weaver
I removed the smog pump and added the Proform 68110 bracket. I also got the Dorman HELP AC Bypass Pulley 34150 in order to get the larger pulley and swap with the Proform. Everything worked perfectly!
However, I do have a 'Check Engine' light now, but I don't know why. I plugged the open valve that was left from the smog pump delete. Only the pump and hoses were removed; nothing else was tampered with.
The truck runs great.
  #39
Old 06-21-2017, 07:02 AM
Motorhead64's Avatar
Motorhead64
Motorhead64 is offline
Pu
Originally Posted by mramc1
Everyone seems to ask this question, but I don't see any picture threads so I thought I'd share what I did on my engine.
I have a 5.8L in a truck that had severe rust damage to the manifolds and air injection tubes. I replaced the manifolds, but since truck is exempt from emissions testing due to GVW I chose to remove the pump and tubes when rebuilding the truck.
Parts that I used:
Proform 68110 5.0/5.8L smog pump eliminator bracket and pulley from JEGS $55
Ford 5.8L AC delete idler pulley $15
Here is the stock air pump.
First I removed the pulley to get to the through mounting bolt.
Mounted on the truck with stock pump still in place.
Pump removed after removing through bolt and back bolt.
Proform bracket installed.
AC delete idler pulley installed.
This combination with the AC pulley allows you to reuse the stock 5.8L serpentine belt with no guessing lengths or dealing with slipping. If you use the Mustang pulley that comes with the kit your stock belt will be too long.
It's just that easy. I left the air diverter valve and solenoids in place on top of the engine and all electrical connections and vacuum lines hooked up. I removed the air tubes from the rear of the diverter valve and manifolds and plugged the rear of the diverter valve to keep dirt out of it. That's it.
how much different is the size of the pulley of the mustang and the ac idler
  #40
Old 06-21-2017, 07:31 AM
rb_weaver's Avatar
rb_weaver
I'd guess a couple of inches in diameter. If you want to stick with using the stock belt for the 5.8, you definitely need to swap the pulley that comes with the Proform 68110 with the pulley off of an A/C bypass bracket.
  #41
Old 12-07-2017, 08:49 AM
egabriele's Avatar
egabriele
egabriele is offline
Where did you buy the AC delete Idler pulley? I couldn't find it on JEGS where you bought the other part. Thanks.
  #42
Old 04-17-2018, 01:34 PM
1997-f250hd's Avatar
1997-f250hd
1997-f250hd is offline
mramc1. Do you have any pictures up by the upper manifold? Be there is a line that goes there and wondering if you removed it.
  #43
Old 08-07-2018, 05:30 PM
CamoF-250's Avatar
CamoF-250
CamoF-250 is offline
I hate to bring up such an old thread but here it goes...
I have a 1992 F150 5.8L 4x4 w/ an E4OD. The previous own ripped out most of this secondary air system. I have the smog pump remaining but I do not think it is pumping to anything. Anyways I am chasing check engine light 311 on my truck related to the TAD and TAB solenoids. I have replaced each solenoid and ran vacuum to the lower port on each. The top ports are both capped off. The code per my internet searches and chilton manual is thermactor system in operative, right side. With no thermactor system or diverter valve to connect to, how do I fool the computer into thinking the system is operating? Note my EGR system is hooked up and working. I previously had codes for this but was able to reconnect it. I do not know if the back of the heads are plugged properly. Can you do this delete on a 92 with EEC-IV and not get a CEL? The truck does not have CATs, just 3" pipes to cherry bomb mufflers with a 2" bung between for the O2 sensor. The O2 sensor is also new. While unrelated the IAC and TPS are also brand new (was fixing other codes).
  #44
Old 08-07-2018, 05:39 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
The only way you can kill the 311 is to be able to modify the tune in the computer. While it is throwing a code, I'd guess it isn't impacting anything.
I always advocate a catalytic converter, you can get high flow and it provides some back pressure, which you need. You aren't nearly maxing out the 3" exhaust based on the horsepower you are putting out
  #45
Old 08-09-2018, 10:23 AM
CamoF-250's Avatar
CamoF-250
I would like to avoid an exhuast or emissions conversation. But, everyone who has removed this system us just driving around with Check Engine Light 311 on? I just provided a complete picture of the state of my system to find out if I made an error that caused it or if it is another issue entirely that is triggering the check engine light. I also get 512 (i think), the one a bout KAM failed, which may mean I have issues with my PCM.
Do others have 311 on after removing this system?
Quick Reply: 5.8L Smog Pump Delete with Pics
