acceleration problem
Old Jun 30, 2003 | 09:11 AM
tau471's Avatar
tau471
my 94 4.0 ranger is having problems when accelerating through all the gears, it actually loses power and speed and the check engine light comes on every time i accelerate. the spark plugs and wires have been changed within 2 years, also the fuel filter, and o2 sensors have been changed recently. i also have a k & n air filter that has been cleaned and oiled. what else could the problem be? any suggestions would be greatly appreciated.
Old Jun 30, 2003 | 09:28 AM
Rancha9's Avatar
Rancha9
Does the check engine light come on solid, or does it flash on/off? A flashing CEL is the misfire signal, which would explain the low power. If it's a steady one, then you need to have the codes pulled. Double check the plugs to make sure they are the correct ones.
Old Jun 30, 2003 | 10:37 AM
tau471's Avatar
tau471
The check engine light goes on and off, it never stays on permanent. It always comes on during acceleration between gears. thanks
Old Jun 30, 2003 | 11:37 AM
Ken00's Avatar
Ken00
I would check for codes, the ECU does store them.
Old Jun 30, 2003 | 02:03 PM
tau471's Avatar
tau471
how exactly do i check for codes? i had it hooked up to a computer to run diagnositcs but they could never get a reading because the check engine light never stayed on completely.
Old Jun 30, 2003 | 06:59 PM
Ken00's Avatar
Ken00
It should store continous codes. See the tech info post at the top of the forum, there is a link on pulling all the types of codes.
