truck jack?
Old Feb 17, 2014 | 09:32 AM
DKluke's Avatar
DKluke
truck jack?
Was there a stock jack included with the 1965 f100 pickups?
Old Feb 17, 2014 | 01:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3TZ-17080-C (replaced 8C-17080) .. Bottle Jack-1 1/2 ton mechanical / Obsolete
1948/52 F1/F2 / 1953/86 F100/250 / 1975/91 E100/150 & E250 under 8,500 lbs. GVWR
Old Feb 17, 2014 | 07:44 PM
Jigsaw's Avatar
Jigsaw
I have one available. Let me know if interested.
Old Feb 17, 2014 | 10:39 PM
Shadowrider123's Avatar
Shadowrider123
Where was the jack and wrench stored?
I was thinking about installing the underhood setup off a later truck.
Old Feb 18, 2014 | 06:58 AM
Jigsaw's Avatar
Jigsaw
That was my plan too, but I never got around to it. I have the mounting bracket, lug wrench and jack handle too.
Old Feb 18, 2014 | 03:59 PM
Roger Carter's Avatar
Roger Carter
This subject was discussed here a while back. As I remember, there was no real definite answer as to where the jack and handle were stored. General consensus was they were tossed under the seat, or in the side tool box if so equipped.
I have searched through factory parts books, sales manuals, shop manuals and original owners manuals looking for the answer. Hope you have better luck than I did.
Roger Carter
Old Feb 19, 2014 | 07:47 AM
DKluke's Avatar
DKluke
Truck Jack
Thanks for the responses. Mine is a Standard Cab. ND, was is stored under the hood like the 70's models?
Old Feb 19, 2014 | 09:26 AM
NumberDummy
Jack located underneath the seat along with the lug wrench and jack crank handle.
Jack could also be placed into the center of the spare wheel, if located in the frame mounted tire carrier.
1967 was the first year that the long jack crank handle was clipped to the front of the radiator support (no parts catalog pic).
AFAIK, 1978 was the first year the jack was located under the hood.
Old Oct 18, 2017 | 10:34 AM
F100_1966's Avatar
F100_1966
Hi folks - my first post here. So, I recently inherited a nice 1966 F100 long-bed from my father-in-law who is getting to the point he cannot handle the heaviness of the steering and non-assisted brakes. The truck is in decent condition, and drivable, but has some issues from simply being under-used over the last couple years.
Here is a pic:
I'll be giving it a good going over in the coming weeks, but for now I have couple simple questions.
The truck came with a bottle jack and folding winder, lug wrench, and also a cross-lug wrench. I've cleaned and painted these rusty old things up, and they now look sharp once again. However, I am not sure the cross-lug wrench belongs to the truck. Is that right? Was one ever provided
Beyond that, I am trying to figure out where the jack, its winder, and lug wrench go. Some say under the hood (I dont see any brackets) some say under the seat (again, no brackets). I don't want to just have these things clattering away in the cab or in the bed.
Old Oct 18, 2017 | 07:13 PM
Roger Carter
Here is a pic:
Hello, and welcome to the site. Sweet looking truck.
Lots of good people here, with all sorts of knowledge about these old trucks. However, seems like a specific answer as to where the jack, handle and lug wrench were securely stored remains unanswered, other than to toss it under the seat.
Brackets and clips from later F-series could be utilized easy enough, and maintain that "original" appearance. My '78 Supercab mounts the jack under the hood, on the driver side inner fender, and the lug wrench and jack handle snap into clips on the cab floor under the front seat. When the seat is moved all the way forward the wrench and handle are exposed.
Fairly certain the 4 way lug wrench is not original equipment.
Again, welcome.
Old Oct 19, 2017 | 07:13 AM
porter444's Avatar
porter444
I need to do the same for my 66 SB. Have been looking for a jack on eBay or in the catalogs (NPD, LMC, Dennis Carpenter, C&G, and Mac’s) - so far nothing specific to he 66 found. I like the idea posted with the image from the 78, under hood. If anyone has pics to share of their jack placement and info/part numbers I think it would add a lot to this thread. Whatever I end up doing, I will post information just in case someone else is in the same boat. It appears at least a few others are.
Thanks F100 gurus!
Old Oct 20, 2017 | 04:59 PM
NumberDummy
Originally Posted by porter444
I need to do the same for my 66 SB. Have been looking for a jack on eBay or in the catalogs (NPD, LMC, Dennis Carpenter, C&G, and Mac’s) - so far nothing specific to he 66 found. .
No such thing as a specific to 1966 F100 jack, and it's not reproduced. You'll have to find a user....see post #2.
1969/91 Econolines used the same jack, lug wrench and folding jack crank handle (that was an accessory for F100/250's).
Open the right back door of these Econolines, everything is there at the end of the quarter panel.
Old Jun 23, 2023 | 12:32 PM
FordsForever12's Avatar
FordsForever12
2nd Gear
Ford F100 bottle jack
I know this is an old post, BUT do you still have that jack? Or do you know where I can get one?
Old Jun 24, 2023 | 09:36 AM
Grampa69's Avatar
Grampa69
My 64 has the original jack in the side compartment. I used it the other day. It grumbled at me as I cranked it up under the load of the truck. I didn't see any way to lube it.
Old Jun 24, 2023 | 09:52 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
You can frequently find them on eBay. It’s harder to find the folding handle/crank, you’ll just need to look on there every day or so till one shows up. You can also contact Brian Morrison at Slick Truck Parts, he’s got quite a bit of stuff.
