What do you think of the 6.2 Transmission
on
Hi everyone-
I have about 2500 miles on my 2014 XL350 CC 4x4 with 4.30 gears and I was wondering what others with the 6.2 think of the transmission action/throttle response?
If I'm rolling at a slower speed and I just romp on it the truck just seems to rev up and wind itself up tight but not really go anywhere until it catches the next gear. If I get the thing rolling along pretty good and then mash it the things rips! My 2002 with a 6.8 V10 4.30's kind of did the same thing.
My 6.2 tranny feels great when I'm on the throttle steady but when I'm in heavy traffic, behind grandma, coasting and on and off the gas it seems like the computer gets confused and it doesn't know what gear it wants to be in. RPM's are up and down.
I really like the manual option as you can hold it in the gear you want or shift it as you want up or down with a flick of the finger.
The tranny also seems a but sluggish when it is cold. I think the electronic solenoids like the fluid to be warmer before they work smooth.
Just wondering what others think of their 6.2 tranny action.
Later-
RRRAVEN
Later-
RRRAVEN
so far I like it..i got the 6.2L with winter being super cold I let it warm up,, but I like it so far over my 5.4 tranny. I agree it is not neck snapping putting along behind grandma, I think the weak link is 3 to 4th..seems theres a tad of a lag before she goes,, but I only have 1600 miles on mine and will see in spring if warmer temps helps..i do like this 6 spd tranny.
on
On the drive home from work yesterday I started playing around a bit with the auto/manual and gear lock out on the transmission. If you have the tranny in D and then toggle the +/- button the gear indicator lights light up so than you can actually see what gear the tranny is in while you are drivng. That gives you a better feel for what the transmission is actually doing while you are driving. Another thing you can do while in that mode is lock gears out, say to stay out of 5th and 6th while in town or in heavy slower stop and go crap. Just toggle the minus (-) button and the 6 light will go out, do it again and the 5 light will go out. So now you have 5th and 6th locked out and you will only see the 1st thru 4th indicator lights lit. All of this is in the owners manual. I've read that section a few times but only messed with it for the first time yesterday. I guess it just takes getting used to and just getting familiar to a modern automotive transmission control unit and how it was programmed from the factory. Is it optimal? Who knows? At least it can be aftermarket programmed if that's your deal or Ford can flash program it with an update it is available.
That function has been around for the past 3 years. I do like the fact you can lock out some gears if you prefer but just be prepared for worse fuel economy. although when your driving around town with the stop start by the time you get to 6th your looking to slow down..But it is the trade off to better mpg's as you drive. I like this tranny over the last SD I had with the 5.4.. that was a slow dog,, at least this 6.2 seems to have more getup..Nice to have choices for your driving needs..
I see guys are adding modified computer chips in there 6.2L. It changes the shift points of the truck. Do you find any fuel mileage increases with these chips or is it just faster throttle response and does that diminish your MPG's?
