Input voltage to ignition coil
Old 07-02-2014, 12:23 AM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
On my '71, the coil is powered by a resistor wire from the ignition switch. Running voltage making it to the coil is only 9.4VDC. I have a pertronix conversion, so points are no longer an issue.
I'm wondering if I can replace the resistor with a straight wire and get full voltage going to the coil without burning something up? It's an aftermarket ACCEL coil. So it should be up to it right?
In theory, it makes sense that if the coil gets more power, it will throw out more power, resulting in stronger, hotter spark. Which, on paper, means better MPG, more power, better throttle response, easier starting, and no downsides. But what about in reality?
Will putting 14 volts to the coil burn it up?
Will the gains really be that big?
Has anyone done this before?
I might rig up an experiment where I hot wire the coil to the battery and see what happens.
Old 07-02-2014, 06:31 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
If your new coil is designed for no external resistor, then yes, bypassing the resistive wire is proper procedure. The Pertronix module in distributor requires full battery voltage, not powered through the resistive fire. Results may vary, but a high output coil can allow you to open up spark plug gap to .040/.045 resulting in a slightly larger/hotter spark. While improved starting and possibly a "slight" mileage increase may be noticed, don't expect huge gains.
Old 07-02-2014, 09:42 AM
351Cleveland C4
Yea I'm not expecting huge gains, I just don't like the idea of anything running off resisted power.
Old 08-31-2014, 11:49 PM
krooser's Avatar
krooser
krooser is offline
While you are testing this make sure you don't leave your ignition on for more than a minute or two… the Pertronix deals are known to fail if the power to them is left on without the engine running… I found out the hard way.
Old 08-31-2014, 11:52 PM
351Cleveland C4
Yep. I just did this mod about a week ago. Runs good. Cruises better, smoother all around. Good mod, good results.
Old 08-31-2014, 11:59 PM
krooser's Avatar
krooser
krooser is offline
Good deal...
HillBillyBuddha
17
02-02-2019 06:01 PM
Brad Brown
Electrical Systems/Wiring
01-04-2012 11:36 PM
qman
18
07-10-2005 11:28 PM
MuchToMyDelight
10-25-2003 04:30 PM
jeffh
06-09-2003 09:02 PM
Quick Reply: Input voltage to ignition coil
