Sponsored by: Real Truck
Engine died suddenly HELP!!!
Old Feb 14, 2014 | 03:34 PM
63DH8's Avatar
63DH8
2004 F-250. 6.0 I was driving down the road when the engine dies. It was like I had turned off the key. When I tried to restart it, it was no click, no starter sound, nothing. The glow plug light remained on, even while turning the key over. Any ideas on what could cause this?
Old Feb 14, 2014 | 07:41 PM
senix's Avatar
senix
Sounds like batteries or alternator. Have you tried to jump it?
Old Feb 14, 2014 | 07:48 PM
Forddiesel06's Avatar
Forddiesel06
X2 check for that and maybe loose wire or connection.
Old Feb 14, 2014 | 07:51 PM
63DH8's Avatar
63DH8
The batteries has 14.5volts. Headlights were bright. I'd think the starter would have at least clicked if the batteries were low.
Old Feb 14, 2014 | 07:55 PM
63DH8's Avatar
63DH8
I checked all the fuses and wires where I could get my fingers on them. What gets me is, after allowing the truck to sit for almost an hour, it started and ran for 10-15 minutes before dying again. It hasn't started since.
Old Feb 14, 2014 | 08:04 PM
senix's Avatar
senix
Bad Pyrometer?
Old Feb 14, 2014 | 08:17 PM
truculent's Avatar
truculent
Security chip loose in socket?
Old Feb 15, 2014 | 11:06 AM
63DH8's Avatar
63DH8
If you mean security chip as in the type in the key, my truck doesn't have that option.
Old Feb 15, 2014 | 01:38 PM
63DH8's Avatar
63DH8
I'm starting to think its the ignition switch because if the miles my truck has.
Old Feb 16, 2014 | 03:17 PM
63DH8's Avatar
63DH8
Bump.
Any other suggestions?
Old Mar 24, 2014 | 03:15 AM
63DH8's Avatar
63DH8
In case someone else has this same problem. Turns out the problem is the exhaust backpressure sensor. The symptoms were engine stopping as if I had turned off the key. The starter motor wouldn't spin either.
Nate Wengerd
May 28, 2019 09:36 PM
JaySVX
Jul 19, 2018 09:19 AM
jackles
Jul 5, 2015 08:35 PM
dtgl90vt
May 14, 2015 06:47 AM
Resendiz
Apr 13, 2015 11:18 PM
