2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Transmission problem
Old Feb 13, 2014 | 11:07 PM
Jay's Avatar
Jay
2007 Expy EL EB 4WD 156,000 miles.
Today I noticed the Transmission seems to be stuck in 3rd or 4th gear and won't up or down shift. Goes int neutral or Park ok. Wrench icon is on.
Any suggestions?
Old Feb 14, 2014 | 11:39 AM
berry1234's Avatar
berry1234
Take it to a dealer or mechanic you trust? If you have a friend with a code scanner you can try that, but it's more than likely you can't shadetree mechanic it if the trans needs to be opened.
Old Feb 15, 2014 | 07:23 PM
bunky383's Avatar
bunky383
Wrench icon means problems with drive by wire system. I think. It will lock vehicle in limp mode. Defaulting in only one gear.
Sent from my Z10 using IB AutoGroup
Old Feb 20, 2014 | 02:46 PM
Phil-turbodiesel's Avatar
Phil-turbodiesel
Definitely sounds like it's in limp mode. Lots of things to put it there. At minimum I'd suggest check the fluid level. Other than that see if any codes are thrown.
Old Feb 20, 2014 | 02:47 PM
Phil-turbodiesel
here's another thread
https://www.ford-trucks.com/forums/6...limp-mode.html
Good luck!
Old Feb 24, 2014 | 11:31 PM
Jay's Avatar
Jay
It was a cracked electrical connector sleeve going into the bulkhead of the trans. Must be a common problem since Ford dealer had the parts in stock.
Slimmy2600
Sep 10, 2014 08:05 AM
bob0312
Apr 16, 2010 02:25 PM
lccpondguy
Feb 4, 2009 11:40 AM
jessman1128
Mar 13, 2005 11:29 PM
jethro
Jul 4, 2001 11:14 AM
