Engine Miss &Stalling
Old May 28, 2002 | 08:33 PM
RJMACK's Avatar
RJMACK
1991 F150,5 liter,E4OD.When passing or going up hills the engine skips or misses,also when stopping after highway driving the engine quits.Have to give it lots of throttle to keep it going. The tach jumps all the time also.Changed plugs,wires,distributor cap and tps.Checked fuel pressure koeo 35 psi,30 when running at idle.HELP!!
Old May 28, 2002 | 09:15 PM
psmallme's Avatar
psmallme
[updated:LAST EDITED ON 28-May-02 AT 10:16 PM (EST)]Sounds familiar,I have a recent post with my problems and some good advice, that I received 93 302 F150 gas mileage check it out.
Phil
Old May 29, 2002 | 10:30 AM
RJMACK's Avatar
RJMACK
Thanks for the info.I'll tell you how I made out later RJ.
Old May 29, 2002 | 11:10 AM
winfordr's Avatar
winfordr
If your tach is erratic, then there is an ignition problem BEFORE the coil. Either in the ignition module, or the sending unit (pickup)in the distributor, or wiring between them.
Winford
Old May 31, 2002 | 10:15 AM
RJMACK's Avatar
RJMACK
I tried a new tfi module but it did not fix the problem.I'll try your suggestion-sending unit next. Thanks RJ>
Old May 31, 2002 | 11:15 AM
mikej's Avatar
mikej
Post Engine Miss &Stalling
