05 excursion
Old Feb 10, 2014 | 08:27 PM
Magnus E's Avatar
Magnus E
Make sure to check the injectors. Bad injectors will make it slow, especially cold and if you're not used to diesels you may not realize the injectors are ticking louder than normal.
Old Feb 11, 2014 | 09:16 PM
Misky6.0's Avatar
Misky6.0
Listen to Money Pit !!
Get the SG2 BEFORE you buy to really be able to tell what you are looking at.
The "turbo lag" is real bad in stock form, at least it was on mine. I could never pull out in traffic, it drove like I had 2 throttle position gradual until about 5-10 MPH and then I had the thrill of full turbo mode. I had my FICM repaired by Ed@ficmrepair and got it reprogrammed with an atlas40 calibration, which completely removed the turbo lag.
Lots of 6L for sale because previous owner knew something was wrong and got out. Take your time and get the SG2 !
Old Feb 12, 2014 | 09:58 AM
edshog's Avatar
edshog
thanks so much, for everones help
Old Feb 12, 2014 | 10:18 AM
nmlewis's Avatar
nmlewis
Tire size
You said that the truck has different tires and rims. Larger tires do effect gear ratios. Which will effect take off. You should change the axle ratios when running larger tires.
That being said even with the stock turbo lag the 6.0 should still take off like a beast once the turbo has kicked in.
Get a printout from ford using the vin number to see what services have been done. It should show up in the system
If the oil cooler has had to be replaced a couple of times, but the egr has not ever been replaced I would pass on the truck.
Old Feb 13, 2014 | 03:17 PM
edshog's Avatar
edshog
thanks for the help, too many people to me to pass, so I did, I am going to get a 2500 suburban with a 6L gas burner, thanks for keeping me from making a bad mistake
Old Feb 13, 2014 | 04:56 PM
LivingLarge's Avatar
LivingLarge
It's not a mistake, but a 6.0 will require some money to make it what it should be. Once it's done there is NO comparison to the suburban. I come off the light and within 2 seconds I'm smoking my 35's yes both.
So, my recommendation is if you don't have the money stay away. But if you can swing it, the 6.0 is a true beast.
Old Feb 13, 2014 | 05:30 PM
WE3ZS's Avatar
WE3ZS
I think you would have been happier with a 6.8 gas Ex than that little Chebby.
Old Feb 13, 2014 | 05:48 PM
LivingLarge
Yeah what Tom said... I loved my v10
Old Feb 13, 2014 | 06:02 PM
Vince79vette's Avatar
Vince79vette
^^ what he said. I love my v10.
Old Feb 13, 2014 | 06:23 PM
WE3ZS's Avatar
WE3ZS
I tried telling him way back in post #8. Some people just don't appreciate the power, reliability and simplicity of the mighty Triton V-10!
Old Feb 13, 2014 | 06:29 PM
LivingLarge
By far the most reliable vehicle I've ever owned, sold it in perfect condition with 228k. Never let me down, only reason why I sold it wife complained I had too many toys at the time.
Old Feb 13, 2014 | 07:13 PM
Money-Pit's Avatar
Money-Pit
Was it something I said?
That was odd....he went from being interested in a diesel EX straight to a buying a gas Suburban....and skipped the possibility of the V10.
Hopefully the Suburban does well for you.
BrentcAK
Feb 3, 2019 08:27 PM
Sarge261
Jan 11, 2012 07:59 AM
Hunter,DDS
Feb 5, 2010 04:51 PM
Zoombah
Jul 22, 2009 09:44 PM
mjlevi
Jan 4, 2008 07:01 AM
