94 explorer AC
Old Jun 29, 2003 | 12:56 PM
mikeottney's Avatar
mikeottney
94 explorer AC
where do I hook the recharge hoses on my 94 explorer, it says to put into "low side", but I cannot locate.
Old Jun 29, 2003 | 01:34 PM
I am Danll's Avatar
I am Danll
94 explorer AC
the line coming from the fire wall going to the evap ciol in front of the radiiator and then up tp the compressor is the all a part of the low side look for a fitting on the accumulator cartige also it will be in this same section.
iIf you csant find the fittings it sounds like you havent hooked up a set of gages and gotten readings WHY are you trying to add refrigerant to a system you havent checked to see that it needs it yet???
