Yet another V/B Code Spring Question
Old Feb 10, 2014 | 05:29 PM
robert_l_ross's Avatar
robert_l_ross
Originally Posted by RobRoss
What is the difference between 2" shackles and hanger/shackle lift?
I THINK the shackle is just that - the shackle alone on one end, the stock hanger on the other.
The hanger/shackle is the shackle on one end and a different hanger on the other end.
When you add only one, the axle isn't at the same alignment as it was stock since you only changed the mounting point of spring on one side. A shackle on the rear with the stock front mount will mean the axle will point 'down' in relation to the ground more than it did stock. Since the V code springs may be "taller" (not as 'flat' as the ones he took off), that angle is even more off in relation to the frame/transfer case.
If you add to both front and rear, then the angle stays the same in relation to the ground, but off "not as much" in relation to the frame/transfer case.
...hard to explain without pics...can someone confirm I'm explaining this right?
Old Feb 10, 2014 | 05:30 PM
Tracktor's Avatar
Tracktor
Originally Posted by robert_l_ross
...also a side pic of the rig as it is now?
No pics at the moment but positive everything was stock. 05 6.0 diesel. I read in a few places that with modded b's you would need a 2" lift on the front so it can't be that uncommon? I will say it's dead level now as I hate the rear high look that comes stock..........Edit, yes a shackle lift is just the rear shackle mounts of the leaf springs. It changes the camber & the driveling angle a bunch. I only did it to get the stance where I wanted and will upgrade to a Hanger/shackle lift...............I also am getting a slight vibration from about 15/25 now with the shackles...........
Old Feb 10, 2014 | 06:28 PM
robert_l_ross
I can say from my experience I replaced the stock springs with V codes and modified B codes (verified via the door sticker) using the thicker leaf spacers and adding the bottom two leaves from my stock springs and using the original stock blocks.
That put me just off of level (rear high by 1/4"). I haven't read anything about the height issue UNLESS it was only a Modded B swap without front V codes or a shackle/hanger lift.
So the next question...are you 100% sure the fronts you swapped were V codes? Pics would help greatly when you get the chance. I have yet to hear of anyone who did a V/Modded B that had 2" of rake. I have heard of people who used the taller blocks as a rear lift then added lift to the front, but on a "pure" V/Modded B done as the instructions say, your rake should be minimal...nowhere near 2".
Did you do the work or did someone else do it?
Old Feb 10, 2014 | 06:35 PM
Tracktor's Avatar
Tracktor
I did the work myself. The springs were pulled from the truck by a friend who runs a wrecking yard so I know for sure they are all correct. Cary @ CT performance is the one who recommended 2" in front to level in one of the threads I read. Every truck is different, though just stating my experiences. YMMV..............
Old Feb 10, 2014 | 07:05 PM
robert_l_ross
Oh, I agree...just the first time I have heard this with a Mod B AND front V swap...I've only heard of needing additional left on the front when doing just the rear Bs...something like 1" for rear B's only, 2" for Modded B's (and that still left some rake). That was why I wanted to see the pics...a good half dozen of us did V/Modded Bs wothout this issue...so it would be good to figure out how yours turned out this way.
Old Feb 10, 2014 | 07:20 PM
MalwareDRay's Avatar
MalwareDRay
I don't 100% agree with the idea the door sticker is always right.
The PO of the vix could have replaced the springs for whatever reason.
Either way, even if the sticker is right, no used spring us ever the same so your results will always vary when choosing that route.
Sent from my Galaxy Note 3 using IB AutoGroup
Old Feb 10, 2014 | 08:06 PM
VQT's Avatar
VQT
I don't think other said the door sticker is 100% correct but that the only way to see it was on the truck. If the owner changed the springs, it would be a better rate than the V/B so it a win win.
If you want to be sure, buy from Ford and it not that bad if you buy from Tousley and Sunrise if there isn't any yard within 250 miles of your home to get it from.
Old Feb 11, 2014 | 07:17 AM
MalwareDRay
I thought that buying from Ford was no longer am option?
I'm happy with what I got from the yard but just saying
Old Feb 11, 2014 | 07:41 AM
RobRoss's Avatar
RobRoss
Nope, perfectly clear! Thank you very much! I was only thinking about the shackle end of the spring.
Anyway, that being said, I most likely won't run a different shackle in the front. Right now I'm leaning towards V/F spring swap...any thoughts?
Old Feb 11, 2014 | 10:16 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I have F codes on my X. They ride real nice. I did do the mod on them for the extra 2"...still a good ride IMO.
Old Feb 11, 2014 | 03:00 PM
ithaca1230's Avatar
ithaca1230
I did the V-modded B code swap and had the rear quite a bit higher than the front so I added the next leaf fronm the old rear leafs to the front and got another inch. Now the front and rear are about within an inch I think. It has been a few months now so all should be worn in well. I should check again and see
Old Feb 11, 2014 | 04:54 PM
robert_l_ross
...maybe it's the 200-250lbs I have in the back all the time that is driving the back down?
I wouldn't have thought that would have sucked up an inch of suspension travel though...and I haven't heard of this particular stance before either. I wonder if Stewart has seen/heard of it?
Old Nov 27, 2014 | 01:41 PM
  #28
rowekmr's Avatar
rowekmr
A late question why aren't the anti axle wrap springs carried over and also is the mod B just for lift or does it add capacity or is it needed for another reason?
Old Nov 27, 2014 | 02:14 PM
  #29
robert_l_ross
The stock springs are soft enough that the axle can torque them...the combination of the stiffer B codes and the additional 2 leaves from stock make the anti axle leaf unneeded. Plus, putting it back in raises the rear another what, 1/2"-5/8"? (whatever the thickness of the anti-wrap leaf and the spacer is). And then you'd have a serious rake over the V's in front.
Old Nov 27, 2014 | 03:14 PM
  #30
rowekmr's Avatar
rowekmr
Happy Holidays!
Ok makes sense this spring swap has had me puzzled more than anything else about my truck so trying to get a handle on things. I asked because I will have a shop do it and I have found keeping things simple are best when others are doing the work. I thought about a plain B swap (that others have done) with F350 block to make up for the lost of lift instead. Do you think this will be an equivalent ride and gain of capacity? I just see the shop messing up the lower 2 springs and spacers swap. If not I will try to print out directions and have them mod the B springs.
Jeff Ro Goodall
May 11, 2022 03:59 PM
Xcursion88
Jul 29, 2017 07:03 PM
SNIPER168308
Jan 16, 2016 06:23 AM
2002exPSD
May 27, 2015 07:30 AM
DaveandJennyP
Mar 22, 2009 09:16 PM
