Front springs difference ?
Old Feb 5, 2014 | 04:17 PM
jim collins's Avatar
jim collins
On the dent side front I-Beam axles is there a difference in the right and left coil spring ? I just got my new front springs from "Moog" and one is marked for Drivers side . The tag is a pretty tough plastic tag sealed to the spring so it will have to be cut off to remove it. The tag has some words i can't read and the words i can read that say "Drivers side only ", on one of the springs. Would there be a different spring rate on the drivers side for some reason ?
They look real good with what looks like a powder coat finish.
Old Feb 5, 2014 | 06:10 PM
GLR's Avatar
GLR
Maybe for the additional weight of the driver.
Old Feb 5, 2014 | 07:47 PM
HIO Silver's Avatar
HIO Silver
And/or air conditioning... typically.
Old Feb 5, 2014 | 08:01 PM
jim collins
My 73 does not have A-C , so i am thinking ' drivers weight' .
They are --Moog #8228
Listed for
66-79 F-100
75-79 F-150
66_79 F-250
All standard cab original fit .
I will do as instructed but it's new to me .
Old Feb 5, 2014 | 09:49 PM
czaroc's Avatar
czaroc
I seem to remember a thread from way back talking this very thing. I believe the consensus was yes, the driver side springs are stiffer.
Old Feb 6, 2014 | 07:19 AM
jim collins
I thought i could remember reading about the difference before. But i never knew if it was here or on some other forum. I can see where the engineers would assume there's only the driver most of the time and add enough for a couple of hundred lbs.
Old Feb 6, 2014 | 08:51 AM
GLR's Avatar
GLR
We had trouble doing a wheel alignment on a guy's car once. He kept complaining about "pulling" and tire wear. Finally did an alignment with the guy in the vehicle (he weighed close to 300 pounds). Everything was fine after that.
Ben Samways
May 2, 2018 10:34 PM
The Eddie
Jan 19, 2013 04:41 PM
martin441
Sep 22, 2009 07:28 PM
workingdog
Jan 12, 2008 05:23 PM
Narwhal
Dec 20, 2005 09:05 AM
