oil life
Old Feb 13, 2014 | 09:46 AM
senix's Avatar
senix
On the label it should indicate CJ4, if not then I would not use it.
Also if there is a spec # on the bottle then consult your owners manual and it will have the spec # as well. If they match then you are good.
Old Feb 13, 2014 | 09:54 AM
720Deere's Avatar
720Deere
Originally Posted by SultanGris
Regular gas 10w30? The 10w30 they gave me said diesel engine oil on it.
10W30 oil designed for gasoline engines is not going to meet the CJ4 designation. There is a difference in the additives used in the oil.
Old Feb 13, 2014 | 11:51 AM
SultanGris's Avatar
SultanGris
OK, gotcha. Thanks. You guys use 15w40? That's what I use in all my other diesels. Just went with 10w30 cause that's what it says on the cap
Old Feb 13, 2014 | 12:40 PM
senix's Avatar
senix
I use 15-40WT since I tow heavy. My average temps where I live are usually above 20F so that fits well with the 15-40.
AK_SuperDuty
Oct 12, 2023 11:46 AM
Mat523
Apr 8, 2014 02:27 PM
Crewcab Turbo
18
Sep 17, 2011 02:25 AM
pat2724
1997 - 2003 F150
Jun 20, 2007 07:01 AM
61 uni
22
Apr 20, 2007 07:31 AM
