68 cluster problems
Old Feb 4, 2014 | 03:21 AM
f100popeye's Avatar
f100popeye
68 cluster problems
I been working on my 68 f100 swb I been trying to figure out how to get my cab ligh, cargo light, and cluster lights to work can someone please help me I check all the bulbs they are fine also trying to check the fuel gauge and temperature, how can I make them work thanks in advance
Old Feb 4, 2014 | 09:26 AM
Gembone's Avatar
Gembone
for the interior lights it sounds like either something in the wiring harness, headlight plug, or headlight switch. Also check the fuses. The gauges could be a number of things but it sounds like you are not getting power out to all these items. I would also make sure you have all the harness grounds properly grounded.
Old Feb 4, 2014 | 11:48 AM
f100popeye's Avatar
f100popeye
Do you known how can I find a diagram or something like that I have headlights and signal lights
Old Feb 4, 2014 | 12:17 PM
Gembone's Avatar
Gembone
1968 wiring diagram here
here is the main diagram page in-case you need others, HERE
Old Feb 4, 2014 | 12:22 PM
f100popeye's Avatar
f100popeye
Thanks I'll take a look at it when it stops raining hopefully its something small
Old Feb 4, 2014 | 05:34 PM
DeeV8er's Avatar
DeeV8er
Light Switch Wire Colors
Here's a pin-out image I made of the light switch for my '67. Knowing Ford, the wire colors on yours should be the same.
Old Feb 4, 2014 | 06:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Good Job Dee. Simplicity in it's greatest form!
Old Feb 4, 2014 | 09:28 PM
orich's Avatar
orich
Does the cargo light switch **** light up red when you pull it out this is on the dash, Dark Red **** switch for it?
Dash Cluster lights are controlled by turning headlight switch **** right to lite up & left for off.
Dash Gauges not working or showing much movement mostly little small voltage regulator backside of dash..
orich
Old Feb 5, 2014 | 02:37 AM
RichS2659's Avatar
RichS2659
As Orich says, the ICVR.
Old Feb 5, 2014 | 09:38 AM
f100popeye's Avatar
f100popeye
orich
Yes the the **** cargo switch lights up but cargo wont work
Old Feb 5, 2014 | 10:18 AM
orich's Avatar
orich
Ok you may need to remove cargo light cover and remove light bulb from the socket, clean socket replace bulb as needed as they hold moisture inside and don't make a good ground contact..
Also check for 12 volt at the cargo socket..
orich
Old Feb 8, 2014 | 04:48 PM
f100popeye's Avatar
f100popeye
Ok I finally got to work on it today all of your advices make me finish the work I took some pictures of how it was and the magic it does
Old Feb 8, 2014 | 04:49 PM
f100popeye's Avatar
f100popeye
Old Feb 8, 2014 | 04:52 PM
f100popeye's Avatar
f100popeye
It was really oxide just grab some sand paper and some elbow grease got the job done dash and dom light work, but the cargo still no light on it :c
chopperfreak
Mar 1, 2019 07:48 PM
ZackWarning
Oct 7, 2014 10:19 PM
slucent
Sep 3, 2006 01:53 AM
JoeBlow
Sep 27, 2004 02:51 PM
460 Crew
Feb 6, 2004 06:01 PM
