1. Open hood and remove plastic trim panel covering the top of the grille assembly.
2. Detatch the headlight housing assemblies and remove them from the vehicle.
3. Remove the grille retaining screws located in the headlight openings.
4. Remove the clips securing the lower half of the grille.
5. Detatch the screws securing the upper half of the radiator grille and remove the grille from the vehicle.
6. Remove old grille....Use some force if necessary.
The next steps are different depending on what aftermarket grille you got.
