351W EFI Qualifier Intake
Old Feb 8, 2014 | 11:04 AM
Conanski's Avatar
Conanski
Originally Posted by TheGageinator
I might just use factory intakes because I won't be above 3500 rpm often...
You may be a perfect candidate for the Edelbrock truck intake, the 5.8 will produce more torque than stock at all rpms with improved topend components all the way up to ARR185 territory.. assuming the motor has a cam that targets low rpms which you have. If that is too pricey for you the Typhoon or Qualifier will provide added airflow and therefore more torque over the stock intake, no the runners aren't as long as the Eddy truck but they're close to the same length as the stock runners and are therefore tuned to roughly the same rpm range.
Old Feb 9, 2014 | 07:10 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
There you go, and I almost had him convinced he didn't need to buy that Typhoon lower and Performer 5.0 upper from me. Would a 1" phenolic intake spacer put the runners close to the truck intake length? Because I've got one of those to go with them. Was gonna use it all on an F250 project I was forced to abort...
Old Feb 9, 2014 | 10:03 AM
Conanski's Avatar
Conanski
Yes a 1" spacer would make it about the same.
Old Feb 21, 2014 | 09:46 PM
TheGageinator's Avatar
TheGageinator
Sounds sweet to me! Yeah I'm still down to buy that intake setup. Check your pm's bud.
Thanks guys
Old Mar 23, 2014 | 03:58 AM
akdanstar's Avatar
akdanstar
I bought the Professional Products - Typhoon upper and lower intakes for a 91 ,f-250.
What a big POS these are after taking them out for a fit up and inspection , A Great Big Fail.. inside matchup is off 1/8 , using my Ridgid See Snake micro I really got a clear look inside. Shining a flashlight though the tops reveal total mismated ports
The casting is terrible inside very rough misshapen , the outside is misshapen some paces look patched, inside grinding and cut marks throughout.
I could not recommend these, you will get what you paid for . This cost me $390 & free shipping , wasted money . The upper cover gasket was screwed together wrong gasket holes didn't line up, the lower does not fit the heads correctly it seems I need to ream the holes.
Do Not BUY the cheapest parts Professional Products - Typhoon is not a good value.
Now I'm buying Eldebrock the matched set Performer RPM II EFI Intake Manifolds #7185,,,,update just bought them from AutoAnything in CA. $641.24 free shipping to Alaska , that is a deal,, Made In America By Americans
__________________
Old Mar 24, 2014 | 02:03 PM
akdanstar's Avatar
akdanstar
americans building Edelbrock ,,enough said ?
can you watch a P.P. Typhoon ?
Old Apr 21, 2017 | 05:20 PM
baddad457's Avatar
baddad457
Hey thanks for the reply!
Engine specs
351w efi
Bore 4.030
Gt40p heads
9.83:1 compression
COMP CAMS K35-255-5
Headers
under drive pulleys
4:10 gears in the g
It's going to be a tow truck only.
Skip the under drive pulleys. They're not going to net you any power but will possibly cause over heating and poor charging from the alternator
Old Nov 3, 2020 | 10:45 AM
trendyvan's Avatar
trendyvan
Here’s a idea
https://bcbroncos.com/shop/fuel/efi/...-early-bronco/
BuickBrian
Ford Truck Parts for Sale
Dec 21, 2016 11:25 AM
mdh627
Jul 20, 2003 10:34 AM
bmac6446
Apr 20, 2003 10:19 PM
